Calculate Integral of cos ax/sinh bx from 0 to infinity | Integration Question
  • Context: Graduate
  • Thread starter Thread starter Nima
    Integration
The discussion revolves around the calculation of the integral of cos(ax)/sinh(bx) from 0 to infinity. Participants explore various methods, including differentiation under the integral sign, and express uncertainty regarding the convergence of the integral.
  • One participant presents the integral of sin(ax)/sinh(bx) and asks for help in calculating the integral of cos(ax)/sinh(bx).
  • Another participant suggests using Leibniz's rule of differentiation under the integral sign as a potential method for solving the problem.
  • Some participants express confusion about the implications of differentiating with respect to "a" and the resulting terms that appear in the numerator.
  • There is a mention of a mistake in the formula used by a participant, who later corrects it and acknowledges the confusion caused.
  • One participant speculates that the integral of cos(ax)/sinh(bx) may diverge but expresses a desire to find the antiderivative to confirm this hypothesis.
  • Another participant indicates that differentiating under the integral sign may not require the specific formula initially discussed, suggesting an alternative approach.
Participants do not reach a consensus on the convergence of the integral or the best method to solve it. Multiple competing views and uncertainties remain throughout the discussion.
There are unresolved mathematical steps regarding the application of Leibniz's rule and the behavior of the integral at infinity. Participants express varying levels of understanding and correctness in their approaches.
Nima
Given Integral (Between 0 and infinity) sin ax/sinh bx = (pi/2b).tanh[(api)/(2b)]. Calculate:
Integral (Between 0 and infinity) cos ax/sinh bx dx.
Any ideas? Cheers.
Do u know leibnitz rule of differentiation under integral sign?
-- AI
Jesus. That one neither and I spent some time on it too. Thanks.
Nima, can you report the answer please. Try and use LaTeX (look at the on-line reference for it in the group). Here, I'll start it for you, just select "quote" and add on:
[tex]\int_0^\infty \frac{\cos(ax)}{\sinh(bx)}=[/tex]
If you differentiate wrt "a" under the integral sign,i'd like to know how one gets read o the nasty "x" that will appear in the numerator...:confused:
Daniel.
made mistake with formula
Nima, where you at? I aint' letting this one go. Just differentiate it throughout using Leibniz's rule (and no I didnt' know to do this until they told me). Granted, you have to take the derivative of infinity but just think of the upper limit as a constant 'c' and at the limit as c goes to infinity, it's derivative is still zero. Else, I'll write it up tomorrow.
This is Leibnitz's rule. Just fill in the blanks.
[tex]\frac{d}{dx}\int_{\alpha(x)}^{\beta(x)}G(x,t)dt=G(x,\beta(x))\frac{d\beta}{dx}-G(x,\alpha(x))\frac{d\alpha}{dx}+\int_{\alpha(x)}^{\beta(x)}\frac{\partial G}{\partial x}dt[/tex]
Salty
Edit: I made a mistake with the formula and corrected it. Now I understand what Daniel meant about the 'x' in the numerator. Will need to regroup . . .
Sorry if I caused problems for anyone.
salty,
F(a) = some integral with respect to 'x' containing parameter 'a'
F'(a) = some integral with respect to 'x' containing parameter 'a'
Can u see what i am pointing at?
My mention of Leibnitz's rule of differentiation was just to indicate that u can differentiate under integral sign, as such u don't explicitly need that formula for this problem :)
-- AI
TenaliRaman said:
salty,
-- AI
Alright, I'm stuck. I used Leibnitz rule incorrectly above. Next time I'll double-check things before I say anything Nima. Sorry. Gonna work on it some more and check it with real data before I post anything.
TenaliRaman said:
salty,
-- AI
Seems to me, after looking at it some more, that the cos integral diverges but I don't want to cause more confussion for Nima or anyone else. Would still like to find the antiderivative to prove explicitly that it does. Am I correct in this analysis?
I mean, it would have been a more interesting question if we needed to find out what [itex]\frac{\cos(ax)}{\cosh(bx)}[/itex] was. That's just me though.
  • · Replies 17 ·
  • · Replies 18 ·
