Please help with these two projectile motion problems, thanks
This discussion focuses on solving two projectile motion problems involving angles and vertical displacements. The first problem requires calculating the vertical displacement of a projectile launched at 64.9 degrees after 4.6 seconds, using the final velocity equation and trigonometric relationships. The second problem involves determining the maximum vertical displacements for projectiles launched at angles of 62 degrees and its complementary angle, 28 degrees, both achieving the same range of 220 meters. Key calculations include finding initial and final vertical velocities and applying the range formula R = v²sin(2θ)/g.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine, cosine, tangent)
  • Knowledge of kinematic equations for vertical motion
  • Ability to apply the range formula R = v²sin(2θ)/g
  • Study the derivation and application of the range formula for projectile motion
  • Learn how to calculate vertical displacement using kinematic equations
  • Explore the concept of complementary angles in projectile motion
  • Practice solving various projectile motion problems with different angles and velocities
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators looking for problem-solving strategies in kinematics.
shaunamariexx
A projectile is launched at an angle of 64.9 degrees with the horizontal (x axis) at some unknown velocity. After 4.6 seconds, the object's angle of trajectory is 40.3 degrees above the horizontal. What is the object's vertical displacement at this time in meters? (Hint: first find the magnitude of the initial velocity using the angle of trajectory (draw a triangle and relate components) and the equation for the final velocity in the y direction.The attempt at a solution
I first tried to find the magnitude of the initial velocity using the trajectory but I had some trouble! And then I know there is an equation for the final velocity in the y direction to help with the answer.
#2:
A projectile is lauched at some speed at an angle of 62 degrees and travels a range of 220 meters. The launch angle is then changed, but the projectile is fired at the same speed as the original case and also travels the same range of 220 meters. Find the maximum vertical displacement at 62 degrees, (ymax1), and find the maximum vertical displacement for the second angle (ymax2), and then find the difference between them in meters
I know after I find the ymax values to subtract ymax2 from ymax 1
Let uy= initial vertical component of velocity and vy=final vertical velocity.
Horizontal component of velocity i.e. vx is same throughout the journey.
tan(64.9°)=uy/vx
tan(40.3°)=vy/vx
Taking ratio,
uy/vy=2.5172
uy=2.5172vy-------(1)
Also,
vy=uy-gt
From 1,
vy=2.5172vy-gt
∴1.5172vy=gt
∴vy=gt/1.5172
vy=29.74m/s
uy=74.86m/s
Also, vertical displacement
s=(uy2-vy2)/2g
s=240.80m
For having the same range, the angles should be complementary i.e. θ1+θ2=90°.
(Because R=v2sin(2θ)/g
and if θ1+θ2=90°, sin(2θ1)=sin(2θ2)).
So, the other angle of projection is 28°.
Rest of the calculations are pretty straightforward.
28K
