Geometric Series Test Rather Than Integral Test
The discussion revolves around the convergence of the series \(\sum_{n=1}^{\infty} \frac{1}{2^n}\) and the application of the geometric series test. Participants are exploring whether the series can be manipulated to fit the criteria for this test.
  • Exploratory, Assumption checking
  • Some participants suggest that the series can be expressed in the form of a geometric series, while others question the necessity of manipulation. There is also a discussion regarding the starting index of the series and its implications for applying the geometric series test.
Participants are actively engaging with the problem, raising questions about the validity of certain assumptions regarding the series' starting index. Some guidance has been offered regarding how to adjust the series to fit the geometric series framework, but there is no explicit consensus on the correct approach.
There is mention of a potential misunderstanding regarding the starting index of the series, with references to teacher guidance that may need clarification. The implications of starting the series at \(n=1\) versus \(n=0\) are under consideration.
Bashyboy
[itex]\sum_{n=1}^{\infty} \frac{1}{2^n}[/itex]
Could I some how manipulate this to fit a geometric series, so that I may instead use the geometric series test?
[tex]\frac{1}{2^n}= \left(\frac{1}{2}\right)^n[/tex]
Hint:
No manipulation is required.
Well, I was told by my teacher that n couldn't equal one for the geometric series to be implemented, was he, perhaps, wrong?
Do you mean, n can't start at 1, it must start at zero?
If so factor 1/2 out of your series & change the index accordingly,
else,
Add 1 to your series so that it starts at n=0, and subtract 1 from your result.
  • · Replies 16 ·
