Quick question on find freq/amp
  • Thread starter Thread starter bjon-07
The discussion revolves around a physics lab experiment using a Behr Free-Fall Apparatus to determine the acceleration due to gravity (g). Participants are questioning the relationship between the frequency of the apparatus's operation and the current (Amp) running through it.
  • Participants are exploring the meaning of "Amp" in the context of the experiment, questioning whether it refers to amplitude or amperes. There is also discussion about the relevance of the current to the experiment's goal of measuring g. Some participants suggest focusing on the frequency of the sparks and the distances between burn marks instead.
The discussion is ongoing, with participants providing insights into the relationship between the spark rate and the frequency of the alternating current. There is an acknowledgment that the spark rate may not directly correlate with the frequency of the current, and suggestions to verify specifications of the equipment have been made.
Participants note that while understanding the current may not be necessary for finding g, they wish to be thorough in their lab report. There is a concern about the relevance of certain details to the overall experiment.
bjon-07
Hi all, I am doing my physics lab write up. We used a Behr Free-Fall Apparatus to find g. The apparatus "zaped" a piece of paper ever 1/60 of second. What is the Amp of current running through the machine. thanks a ton.
Whether you are using "Amp" to mean "amplitude" or "amperes" (which I suspect would be the same thing here), neither depends on the frequency.
What does it matter? You aren't interested in the composition of the metal in the stand either. Part of physics is knowing what is relevant and what is not - so if you are worrying about the current required to make the spark your teacher might infer that you are missing the point of the experiment. All you are interested in is the frequency of the spark and the distances between the spark burn marks on the tape.
AM
Sorry for the confusion but why I want to find is clylic rate at which the electricity is alternating. This in theory should well tell me how many times per second the deviced will zap the target. I know its not nessarcy to find g, but I would like to be very througll in my lab reprt.
The spark rate is not necessarily the same as the frequency of the alternating current. The spark is presumably caused by an induction coil with a switch making and breaking contact 60 times/second (like the ignition system on a car). Check the specification for the equipment to find out the number of sparks per second (to verify that it is 60).
AM
  • · Replies 37 ·
