SHM- differential Equations. Finding the constants of Integration from exp. data
The discussion revolves around a differential equation related to simple harmonic motion (SHM), specifically in the form x = A cos(10.7t) + B sin(10.7t). The original poster is attempting to determine the constants of integration, A and B, using experimental data for displacement over time.
  • The original poster questions the values of A and B based on the initial condition x(0) = 0, leading to confusion about the implications for B. Some participants suggest considering the amplitude from the data and exploring different forms of the equation, such as incorporating a phase shift.
Participants are actively engaging with the problem, exploring various interpretations of the data and the implications of boundary conditions. There is a recognition of the experimental nature of the data, and some guidance has been offered regarding the selection of A and B based on the largest observed displacement and the behavior of sine and cosine functions.
The original poster notes that the data includes damping effects and extends beyond the initial time frame discussed. There is also mention of a lack of familiarity with numerical integration methods, which may impact the exploration of solutions.
$id
Hey guys,
bit stuck here with this problem
I have a differential equation for SHM here in the form
x= A cos 10.7t + B sin 10.7t
I need to find the constants of integration. w = 10.7 as above
I don't have anything other than experimental data
Time Second Distance / m
0 0
0.05 -0.008
0.1 -0.008
0.15 -0.008
0.2 -0.009
0.25 -0.014
0.3 -0.019
0.35 -0.029
0.4 -0.036
0.45 -0.045
0.5 -0.051
0.55 -0.056
0.6 -0.054
0.65 -0.029
0.7 -0.012
0.75 0.011
0.8 0.031
0.85 0.055
0.9 0.049
0.95 0.025
1 0.002
1.05 -0.032
1.1 -0.047
1.15 -0.055
1.2 -0.047
1.25 -0.021
1.3 0.002
1.35 0.035
1.4 0.049
1.45 0.054
1.5 0.045
1.55 0.016
1.6 -0.006
1.65 -0.038
1.7 -0.051
1.75 -0.053
1.8 -0.042
1.85 -0.012
1.9 0.011
1.95 0.04
2 0.052
Since x=0 when t = 0
I get A = 0 ... A Cos 0 =0
But then I also seem to get B=0 which makes no sense.
If B is the amplitude of the function then sure it must 0.055m or thereabouts
Any ideas on working out B
I have tried other values but to no avail.
thanks a lot
sid
Edit/ The first value of the data ist he time value and the second one is the displacement value
IF i write the equation in the format
x= A sin (wt + e)
then A is the amplitude and e is the phase shift factor. can I just write down A = 0.055m from the data??
This is very urgent, please advise
sid
What you wrote are ALL the possible solutions to the diff. equation. You need to look at your "boundary conditions" from your data to pick out which solution to use. At t=0, your data shows that you have ZERO amplitidue. Now look at both the sine function and the cosine function. Which one of these would fit your data more accurately?
Zz.
Yes, x(0)= 0 means that the "A" in x= A cos 10.7t + B sin 10.7t must be 0.
I think I would be inclined to look at t such that 10.7t= pi/2= 1.57 or 0.15: that's
x(0.15)= -0.008 so x(t)= -0.008 sin 10.7t. Yes, that's awfully close to identically 0.
If your data were exact, that should match all other values. If it is, rather, experimental measurements, you might want to take t as large as possible. Noticing that your t values go up to 2, 10.7t goes up to 21.4. 13 pi/2= 20.4 which corresponds to t= 1.9. x(1.9)= 0.011 which would give x(t)= 0.011 sin 10.7t.
Yet another way to handle the fact that the data are not exact is to look at the largest value. The largest value of x that I see, with a quick scan is
0.055. Since the largest possible value of A sin 10.7 is A, that would indicate that x(t)= 0.055 sin 10.7t.
The best way to handle it would be to average the values: The integral of
x(t)= A sin 10.7t between t= 0 and t= 2 is A/10.7 cos(21.4). Do a numerical integration of the given data and choose A to fit that. Of course, you don't HAVE to use x(0)= B= 0 (unless that is the one value you are SURE of). There are an infinite number of ways to fit a formula to approximate data.
Thanks HallsofIvy
The data itself goes all the way upto 25 seconds. Although this meant to be perfect, there is some damping as it progresses but nothing much.
I don't think i completely understand your integration method, I don't know anything about numerical integration anyways(paralleogram rule i do know)
I just choose A = 0.055 because it is the largest possible value.
