Proving the weyl tensor is zero problem
  • Thread starter Thread starter Airsteve0
    Tensor Weyl Zero
All Robertson-Walker models are conformally flat, which necessitates that the Weyl tensor must vanish. The discussion highlights the relevant equations, including the Robertson-Walker metric, Ricci tensor, and Ricci scalar. The user attempted to demonstrate this by substituting values into the Weyl tensor equation but encountered difficulties with the Riemann tensor. The solution involves deriving the Ricci tensor and scalar from first principles using the given metric.
  • Understanding of the Robertson-Walker metric
  • Familiarity with the Ricci tensor and Ricci scalar
  • Knowledge of the Weyl tensor and its significance in conformal geometry
  • Ability to derive the Riemann tensor from the metric
  • Derive the Riemann tensor from the Robertson-Walker metric
  • Calculate the Ricci tensor and Ricci scalar for specific cases of K (e.g., K=0, K=1, K=-1)
  • Explore the implications of conformal flatness in cosmological models
  • Study the relationship between the Weyl tensor and gravitational waves
Students and researchers in theoretical physics, particularly those focusing on general relativity and cosmology, will benefit from this discussion.
Airsteve0
Show that all Robertson - Walker models are conformally flat.
Robertson Walker Metric: [itex]ds^{2}=a^{2}(t)\left(\frac{dr^{2}}{1-Kr^{2}}+r^{2}(d\theta^{2}+(sin\theta)^{2}d\phi^{2} )\right)-dt^{2}[/itex]
Ricci Tensor: [itex]R_{\alpha\beta}=2Kg_{\alpha\beta}[/itex]
Ricci Scalar: [itex]R=8K[/itex]
Weyl Tensor: [itex]C_{\alpha\beta\gamma\delta}=R_{\alpha\beta\gammaδ}-\frac{1}{2}(g_{\alpha\gamma}R_{\beta\delta}-g_{\alpha\delta}R_{\beta\gamma}-g_{\beta\gamma}R_{\alpha\delta}+g_{\beta\delta}R_{\alpha\gamma}) + \frac{R}{6}(g_{\alpha\gamma}g_{\beta\delta}-g_{\alpha\delta}g_{\beta\gamma})[/itex]
In order for the models to be conformally flat the weyl tensor must vanish, therefore that is what I have tried to show. By subbing in the values for the Ricci tensor and the Ricci scalar (both of which were given in a lecture by my professor) I arrived at the following expression:
[itex]C_{\alpha\beta\gammaδ}=R_{\alpha\beta\gamma\delta}-\frac{2}{3}K(g_{\alpha\gamma}g_{\beta\delta}-g_{\alpha\delta}g_{\beta\gamma})[/itex]
However, as you can see I am left with the Riemann tensor undefined and I cannot show the weyl tensor to be zero. Any help is greatly appreciated, thanks!
I'm pretty sure your textbook contains the definition of the Riemann tensor, and of the other tensors. Look it up. (You will only need to know the metric to calculate it.) Then, the Ricci tensor is related to the Riemann one through
[itex]R_{ij} = R^k_{\, ikj}[/itex],
and, finally, the Ricci scalar is simply the trace of the Ricci tensor.
So well, I'd recommend you start working from the definitions. It is probably more instructive to derive those forms of the Ricci tensor and scalar yourself, and see if you get the same forms for this specific metric.
