Does QED reproduce classical electrodynamics? How?
The discussion centers on the relationship between Quantum Electrodynamics (QED) and classical electrodynamics, specifically exploring how QED can reproduce classical electromagnetic phenomena, such as the Lienard-Wiechert potential and the electric field distribution of a moving charge. The scope includes theoretical connections and references to existing literature.
  • One participant notes the connection between QED and classical electrodynamics through particle scattering amplitudes, specifically referencing Peskin's work on the Coulomb potential.
  • Another participant suggests that classical electrodynamics corresponds to tree-level processes in QED, which can be derived using the saddle-point approximation.
  • A different participant emphasizes the canonical formulation of QED, highlighting the role of charge density operators and the separation of classical fields from quantum fluctuations.
  • A participant mentions a thesis by Mario Bacelar Valente that discusses the relationship between classical and quantum electrodynamics, suggesting it as a reference for further exploration.
  • One participant reiterates the initial inquiry about reproducing the full solution to Maxwell's equations from QED and seeks additional references, specifically mentioning a book on quantum optics by Mandel and Wolf as a potential resource.
Participants express various viewpoints on the connection between QED and classical electrodynamics, with no consensus reached on the completeness of the connection or the methods to reproduce classical results from QED.
The discussion involves complex theoretical concepts and assumptions about the relationship between quantum and classical frameworks, which may not be fully resolved or universally accepted among participants.
Feynlee
It seems to be a dumb question. But I haven't seen anyone making this connection between QED and Classical EM in a complete fashion. The only example I've seen is the connection between two particle scattering amplitude calculation in QED (Peskin's book), and the amplitude of a particle scattering of a potential in non-relativistic Quantum Mechanics. By making that connection, you can reproduce the equivalent "potential" from QED. In this case, the coulomb potential (see Peskin P121~P125).
But what about the full solution to Maxwell's equations. For example, how would one reproduce the Lienard-Wiechert potential, or equivalently the electric field distribution of a randomly moving charge from QED's calculation? It seems to me, in QED there is no real concept of "potential", all are amplitudes. But there must be some way to connect this QED picture to the Classical relativistic potentials that already worked so well.
Is there any way to do that? Any reference would be greatly appreciated!
Classical ED corresponds to tree-level processes and is obtained within the saddle-point approximation. Similarly, the motion of a particle according to classical mechanics is obtained within the WKB approximation, which is similar in spirit to the saddle point approximation.
Thanks for your reply! Is there any reference you can recommend that shows how exactly this works?
The relation is visible in the canonical formulation. One piece of the gauge fixed QED Hamiltonian is
[tex]\int_{\mathbb{R}^3 \otimes \mathbb{R}^3} d^3x\,d^3y \frac{\rho(x)\,\rho(y)}{|x-y|}[/tex]
with
[tex]\rho = j^0 = \psi^\dagger \psi[/tex]
By expanding the charge density operators as
[tex]\rho = \rho_0 + \tilde{\rho}[/tex]
one obtains a quantum theory of fluctuations on top of a classical background charge distribution. Such a separation as classical fields (determined by Maxwell and Dirac equation) + fluctuations is possible for other field operators as well.
Mario Bacelar Valente wrote an interesting thesis on the relation between the classical and quantum electrodynamics:
philsci-archive.pitt.edu/8764/1/PhD.Bacelar.pdf
Feynlee said:
It seems to be a dumb question. But I haven't seen anyone making this connection between QED and Classical EM in a complete fashion. [...]
But what about the full solution to Maxwell's equations. For example, how would one reproduce the Lienard-Wiechert potential, or equivalently the electric field distribution of a randomly moving charge from QED's calculation? [...]
For the optical sector, you should look at the book on quantum optics by Mandel and Wolf. You cannot fail to see the connection.
  • · Replies 134 ·
13K
  • · Replies 22 ·
  • · Replies 30 ·
