The Rayleigh-Plesset Equation for Sonoluminescence
  • Context: Graduate
  • Thread starter Thread starter Ashiataka
    Sonoluminescence
The Rayleigh-Plesset equation is essential for understanding sonoluminescence, particularly in the context of bubble dynamics. The equation is represented as \(\frac{P_B(t)-P_\infty(t)}{\rho_L}=R\frac{d^2R}{dt^2}+\frac{3}{2}\left( \frac{dR}{dt}\right)^2+\frac{4\nu_L}{R}\frac{dR}{dt}+\frac{2S}{\rho_LR}\). Key variables include \(P_g\), the pressure in the gas, and \(\rho_L\), the liquid density. The discussion highlights the rearrangement of terms and the significance of pressure factors in the equation.
  • Understanding of the Rayleigh-Plesset equation
  • Knowledge of fluid dynamics principles
  • Familiarity with sonoluminescence phenomena
  • Basic mathematical skills for differential equations
  • Research the implications of the Rayleigh-Plesset equation in bubble dynamics
  • Explore the relationship between pressure in the gas and liquid density in sonoluminescence
  • Study the effects of varying \(R\) and \(\nu_L\) on sonoluminescence outcomes
  • Investigate experimental setups for observing sonoluminescence
Researchers in fluid dynamics, physicists studying sonoluminescence, and engineers involved in bubble dynamics applications will benefit from this discussion.
Ashiataka
I'm investigating the phenomenon of sonoluminescence. A quick search has yielded the Rayleigh-Plesset equation as being of use.
[tex]\frac{P_B(t)-P_\infty(t)}{\rho_L}=R\frac{d^2R}{dt^2}+\frac{3}{2}\left( \frac{dR}{dt}\right)^2+\frac{4\nu_L}{R}\frac{dR}{dt}+\frac{2S}{\rho_LR}[/tex]
A brief look on the wikipedia entry on sonoluminescence yields an approximate form.
[tex]R\frac{d^2R}{dt^2} + \frac{3}{2}\left( \frac{dR}{dt}\right)^2 = \frac{1}{\rho}\left(p_g - P_0 - P(t) - \frac{4\nu_L}{R} \frac{dR}{dt} - \frac{2S}{R}\right)[/tex]
Now I'm assuming that P0 = PB and P = Pinfinite. So that gives (when rearranged):
[tex]\frac{P_B(t) + P_\infty(t)}{\rho_L} + R\frac{d^2R}{dt^2} + \frac{3}{2}\left( \frac{dR}{dt}\right)^2 + \frac{2S}{\rho_LR} = \frac{p_g }{\rho_L}-\frac{4\nu_L}{\rho_LR} \frac{dR}{dt}[/tex]
which has the two terms on the RHS being different from the original expression. Firstly, what is pg? And secondly, why do both terms now have a 1/rho factor?
Thank you.
Thank you.
I've managed to get a very faint green streak on a long exposure. It's quite a lovely effect.
  • · Replies 30 ·
