Linear Functions: Showing Properties for Multi-Vars
  • Context: Undergrad
  • Thread starter Thread starter WittyName
    Functions Linear
The discussion revolves around the properties of linear functions, specifically how to demonstrate these properties for multi-variable functions. Participants explore whether it is sufficient to show linearity by fixing other variables or if a more comprehensive approach is necessary.
  • One participant proposes that to show linearity for a multi-variable function f(x,y,z), it may suffice to demonstrate the properties for one variable at a time while fixing the others.
  • Another participant suggests that multi-variable functions can be represented as matrices applied to vectors, indicating that if a matrix can define the function, it is essentially linear.
  • The same participant elaborates on the nature of matrix multiplication and how it relates to the properties of linear functions, emphasizing the importance of dimensions and definitions.
  • A later reply provides links to external resources for further reading on linear functions and vector spaces.
Participants express differing views on the approach to demonstrating linearity in multi-variable functions. There is no consensus on whether fixing other variables is sufficient or if a more comprehensive method is required.
Participants do not fully resolve the question of how to demonstrate linearity, leaving open the possibility of multiple valid approaches depending on definitions and assumptions about the functions involved.
WittyName
Linear functions are functions which satisfy the two properties:
[itex]f(x+y)=f(x)+f(y) \\<br /> f(a*x)=a*f(x)[/itex]
I was wondering how would you show this property was true for multi-variable functions e.g. [itex]f(x,y,z).[/itex] Would it suffice to show [tex]f(x_{1}+x_{2},y,z)=f(x_1,y,z)+f(x_2,y,z) \\ f(a*x,y,z)=a*f(x,y,z)?[/tex] Basically fix all other variables and show the properties are true for one variable, then repeat for the next variable different to the one we chose before.
Or would you have to consider something like [tex]f(x_{1}+x_{2},y_{1}+y_{2},z_1+z_2) \ \text{and} \ f(a*x,a*y,a*z)?[/tex]
Hey WittyName and welcome to the forums.
Basically for multi-variable functions, your function is a matrix applied to a vector and if you can show that such a matrix exists that defines your function, then it's essentially linear.
what you basically do is treat your x as a vector (typically a column vector) and then show that a matrix exists to define your function.
The linearity works because of the nature of matrix multiplication and the properties of multiplying matrices by scalars as well as the distributivity of addition with multiplication where (X+Y)Z = XZ + YZ if all of these are matrices and have the right definitions (i.e. dimension wise).
Thanks for the reply.
Would you know of any sites where I can read more on this?
  • · Replies 0 ·
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 41 ·
  • · Replies 0 ·
