Lenz's law for point charge in time varying magnetic field?
The discussion centers on the behavior of a point charge with mass m and charge +e in a time-varying magnetic field B. Initially, the charge moves in a uniform circular motion with a radius defined by the equation r = mv/qB. As the magnetic field changes over time, specifically with a constant rate of change dB/dt, the radius of the circular motion decreases or increases depending on the sign of dB/dt. The participant questions the presence of induced electromotive force (emf) during this process and whether the magnitude of the emf decays as the magnetic field increases, indicating a complex interaction between magnetic flux and particle motion.
  • Understanding of Lenz's Law and its implications in electromagnetism.
  • Familiarity with the concepts of magnetic flux and induced emf.
  • Knowledge of circular motion dynamics in the context of charged particles.
  • Basic principles of time-varying magnetic fields and their effects on charged particles.
  • Study Lenz's Law and its applications in electromagnetic induction.
  • Explore the mathematical derivation of induced emf in varying magnetic fields.
  • Investigate the relationship between magnetic flux and the motion of charged particles.
  • Learn about the effects of time-varying magnetic fields on charged particle dynamics in detail.
This discussion is beneficial for physics students, educators, and researchers interested in electromagnetism, particularly those exploring the dynamics of charged particles in varying magnetic fields.
cfitzU2
Hello friends,
So I have a point charge with mass m and charge +e entering a uniform magnetic field B at velocity v from the "right". The field is perp to the velocity pointing "in", so I see that eventually this particle reaches a steady state of uniform circular motion (counter clockwise) with radius r = mv/qB
After this point, the field starts to vary in time at, say, dB/dt = c = const >0
I am unsure as to what exactly happens to the particle... here's what I think:
If my expression for the radius is correct, then the particle will eventually (in the limit) come to a rest, since B going up implies r going down.
What I'm particularly confused about is whether or not there is an induced emf in the mean time, due to the circle swept out by the particle... and if so, would it be correct to say that the magnitude of this emf is decaying in time as B goes up? I think this because the flux area is going to zero...
Similarly, if the variation is dB/dt=-c=const<0 then the radius grows... and so does the emf? Albeit flowing the opposite direction to the first case...
This seems weird and, while the math seems straightforward, I'm not so sure about the physics...
Thanks for any explanations!
Does no response mean this is really easy or no one knows it?
Because I haven't been able to find a similar issue... :(
