A ball being shot from level ground with a twist
  • Thread starter Thread starter mooha
    Ball Ground
The discussion centers on calculating the launch angle of a ball shot from level ground towards a wall at a distance "x" using the provided velocity equation, y = -0.5x + 5, for the y-component of velocity. Key equations utilized include v = vo + at, x = xo + Vot + 0.5at², and v² = (vo)² + 2a(x - xo). The participant struggles to determine the initial velocity due to the unknown time of flight and the specific point of impact along the 20 m trajectory. The solution requires incorporating the time dependency of x to resolve the launch angle effectively.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with trigonometric functions and their applications
  • Ability to interpret velocity graphs
  • Study the relationship between time and distance in projectile motion
  • Learn how to apply kinematic equations to solve for unknown variables
  • Explore the use of trigonometry in determining angles of projectile trajectories
  • Investigate the impact of initial velocity on projectile motion
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples of problem-solving in these areas.
mooha
Not a literal twist! It's just a bit more complex.
A ball is to be shot from level ground toward a wall at a distance "x". I am given the graph of the y component of velocity just as it would reach the wall, as a function of that distance x(m). Here's the equation of the line:y=-.5x+5, [0, 20]
What is the launch angle?
v = vo +at
x = xo + Vot + .5at2
v2 = (vo)2 + 2a(x - xo)
So I wrote out all I knew about the x and y components
y: vo = 5, a = -9.8, xo = 0
x: a=0
I attempted to created a triangle of the horizantal and vertical components of velocity and the initial velocity as the hypotenuse solve with trig. I got
sin(θ)= (5)/(V)
tan(θ)= (5)/(vox)
No help.
I really am stuck! Using kinematics, you can't find the initial velocity because you don't know the time. You can't find the time, because you don't know where in the 20 m of the trajectory the ball hit the wall (according to my interpretation of the problem) Ah! If you could help I would be so grateful!
Thank you so much!
x depends on time. Use this dependency.
  • · Replies 38 ·
  • · Replies 21 ·
