Linear Independence: Is this true?
The discussion centers on the concept of linear independence in the context of vectors in a plane within ℝ³. Participants explore whether a vector outside a given plane can be expressed as a linear combination of vectors that lie within that plane, considering different interpretations of what it means for a vector to be "outside" the plane.
  • One participant, BiP, suggests that any vector outside a plane cannot be expressed as a linear combination of vectors on that plane, seeking expert opinions on this claim.
  • Another participant questions the definition of "outside" the plane, asking whether it refers to a plane that does not pass through the origin or if it means a vector from the origin to a point on the plane.
  • BiP clarifies that they are referring to vectors as directed line segments in the plane, indicating a standard approach in parametrizing planes in 3-space.
  • A different participant discusses the distinction between "free vectors" and "bound vectors," explaining that common representations of vectors assume the tail is at the origin, which affects how linear combinations are understood.
  • This participant also notes that a plane not passing through the origin can be represented by adding a constant vector to vectors that lie in a plane passing through the origin.
  • There is a suggestion that linear combinations of bound vectors are always vectors whose tails are at the origin, implying that multiples of bound vectors cannot lie in a plane that does not pass through the origin.
Participants express differing views on the definitions and implications of vectors in relation to planes, particularly regarding the concepts of free versus bound vectors and the conditions under which linear combinations can be formed. The discussion remains unresolved with multiple competing interpretations present.
The discussion highlights potential ambiguities in the definitions of vectors and their representations, particularly in relation to their origins and the implications for linear combinations. These nuances may affect the conclusions drawn about linear independence.
Bipolarity
Consider a plane P in [itex]ℝ^{3}[/itex]. Is it necessarily the case that any vector outside this plane cannot be expressed as a linear combination of finitely many vectors on this plane?
I would think yes; if you tried to parametrize the plane P with two parameters, could we somehow show that there are no values of the parameters for which the linear combination of the vectors on the plane equals the vector outside the plane?
But I need an expert's opinion on this.
BiP
What do you mean by "outside" the plane? Are you visualizing a plane in [itex]R^3[/itex] that does not pass through the origin and visualizing a vector "in the plane" as one that is represented by a directed line segment that is in the plane? Or are you defining a vector "in the plane" to mean a vector from the origin to a point on the plane? - when the equation of a plane is given in terms of vectors, it is usually done by writing a relation that is satisified by vectors whose "tail" is the origin and whose "head" is a point on the plane.
I am actually referring to the former: "directed line segment in the plane". That is, if you take two points in the plane and take their "difference", then you get a vector which is "in the plane". I thought this was standard used in constructing parametrizations of planes in 3-space. Or perhaps I am not very clear in my conceptualization of vectors.
BiP
You are visualizing vectors as "free vectors". I've never seen a systematic elementary exposition of how to deal with them. Illustrations in physics books sometimes draw vectors so their "tail" doesn't begin at the origin of the coordinate system. That type of vectoris called a "free vector". All the common formula involving cartesian coordinates of vectors assume that the "tail" is at the origin. This is the standard way of treating vectors. They are "bound" vectors.
If you regard the vector between the points (3,5) and (4,9) as (1,4) and you regard (1,4) as referring to vector whose tail is at (0,0) and whose head is at (1,4) then (1,4) does not lie on the line segment connecting (3,5) to (4,9). In fact, if you are only using 2 numbers to represent a 2D vector, then you don't have enough numbers to represent both the head and tail of the vector.
Likewise, if you are using 3 numbers to represent a vector in [itex]R^3[/itex] you can't represent both the tail and the head. When we say "a vector in [itex]R^3[/itex]" , this is usually taken to mean "a bound vector specified by 3 numbers insead of a free vector specified by 6 numbers.
In terms of bound vectors, a plane in [itex]R^3[/itex] not passing through the origin can be represented by taking all the vectors that lie in a given plane that does pass through the origin and adding some constant vector [itex]V_c[/itex] to them.
When you ask about a linear combination of vectors , you have to specificy what vectors we can use in the linear combination. A linear combination of "bound" vectors is always a vector whose tail is at the origin. Multiples of a "bound" vector never lie "in" a plane that doesn't pass through the origin..
  • · Replies 23 ·
  • · Replies 51 ·
