In need of mathematica or maple
  • Context: Mathematica
  • Thread starter Thread starter msmith12
    Maple Mathematica
The discussion revolves around solving two systems of equations using mathematical software, specifically Mathematica and Maple. Participants seek assistance in entering the equations into these programs and interpreting the results, with a focus on equilibrium probabilities in a game-theoretic context.
  • Homework-related
  • One participant requests help to solve two systems of equations but lacks access to Mathematica, expressing frustration with manual calculations.
  • Another participant suggests splitting the equations with multiple equal signs into separate equalities for easier input into Maple.
  • A different participant shares results obtained from Mathematica for the first system of equations, noting discrepancies in the equations as originally posted.
  • Another participant reports issues with Maple, indicating that the output differs from Mathematica and presents the equations as interpreted by Maple.
Participants do not reach a consensus on the correct form of the equations or the results from the different software. There are multiple interpretations and outputs presented, indicating ongoing uncertainty and disagreement.
There are noted discrepancies in the equations as presented by participants, particularly regarding the signs and structure of the equations. Some participants express uncertainty about the correct input format for the software.
msmith12
so, this is probably not exactly posted in the right place, but I was wondering if someone could enter a couple of things into a math program for me. I have two simple systems of equations and need the values for them, and unfortunately, don't have mathematica on this computer, and I started working these with pencil and paper, and they did not look very pretty... so without further adiou...
[tex](1-a-b)(1+4x+3y)=a(4-4x-y)=b(2+y)[/tex]
[tex](1-x-y)(1+6a-b)=x(4-2a+8b)=y(6-5a-6b)[/tex]
and...
[tex]a(1+4x+3y)=b(4-4x-y)[/tex]
[tex]x(4a+2b)=y(6a+b)=(1-x-y)(a+7b)[/tex]
i need to find the values of a,b,x,y for each set of equations.
(in case you were wondering where these came from, they are the equilibrium probabilites that player A chooses 1,2,3 and player B chooses a,b,c)
thanks a bunch
~tired of number crunching
and...
thanks a bunch
if you can show me exactly how i enter it into maple i will do it for you.. i have maple 8.. I am not quite sure how to do it when there is two equal signs in the equation like that.
I am not exactly positive, but it should work to split up the three equals signs into two different equalities... so the command should work something like...
sys1:={(1-a-b)(1+4x+3y)=a(4-4x-y),a(4-4x-y)=b(2+y),(1-x-y)(1-6a-b)=x(4-2a+8b),x(4-2a+8b)=y(6-5a-6b)};
ans1:=solve(sys1);
sys2:={a(1+4x+3y)=b(4-4x-y),x(4a+2b)=y(6a+b),y(6a+b)=(1-x-y)(a+7b)};
ans2:=solve(sys2);
hopefully that will work... if not, hopefully i just missed a comma... if anyone who is reading this can provide any insight, I would be much obliged...
thanks
I typed it in Mathematica and get the following:
System 1:
{{x -> 1.70045, a -> 1.3017, b -> 0.865607, y -> -2.48157},
{x -> 0., a -> 0., b -> 1., y -> -2.},
{x -> 0.100997, a -> 0.0937245, b -> 1.05555, y -> -1.54364},
{x -> 0.154481, a -> 0.314785, b -> 0.375722, y -> 0.453553},
{x -> 1.09427, a -> 1.26404, b -> -0.192182, y -> -0.0861005},
{x -> -0.452824, a -> -0.232922, b -> -0.661729, y -> 0.0336715}}
Note: In your original post, you wrote: (1+6a-b). The above solution
is for (1+6a-b)
In your second post, you wrote: (1-6a-b). In this case Mathematica gives:
{{x -> 1.51463, a -> 1.46436, b -> -1.07928, y -> -2.22261},
{x -> 0.361879, a -> 0.614746, b -> 0.252376, y -> 1.22748},
{x -> -0.957595, a -> -0.703093, b -> -2.07493, y -> 0.487984},
{x -> 1.10136, a -> 1.26672, b -> -0.194326, y -> -0.116498},
{x -> -0.011296, a -> 0.132274, b -> 0.271161, y -> -0.0179704}}
For the second set of equations, you only gave 3 equations.
maple 8 must be a lot different from mathematica because it gave me this
sys1 := {1 - x(1 - 6 a - b) - y(1 - 6 a - b) = x (4 - 2 a + 8 b),
(1 - a - b) (1 + 4 x + 3 y) = a (4 - 4 x - y),
a(4 - 4 x - y) = b (2 + y),
x (4 - 2 a + 8 b) = y (6 - 5 a - 6 b)}
ans1 :=
sys2 := {a (1 + 4 x + 3 y) = b (4 - 4 x - y),
x (4 a + 2 b) = y (6 a + b),
y (6 a + b) = 1 - x(a + 7 b) - y(a + 7 b)}
ans2 :=
as your answer
  • · Replies 0 ·
