Using Energy to Solve Work Problem
The problem involves a truck traveling down a hill and the effects of friction and gravitational potential energy on its stopping distance. The scenario includes parameters such as the truck's speed, the angle of the hill, and the coefficient of kinetic friction.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the work done by friction and its relationship to energy equations. There is an exploration of the angle used in calculations and its implications on the work done. Some participants question the use of variables and suggest clarifying the relationship between distance and height.
The discussion is ongoing with various approaches being explored. Participants are providing guidance on how to correctly set up the energy equations and are questioning assumptions made in the original attempts. There is no explicit consensus yet, but some productive directions have been suggested.
Participants note the importance of using the correct variables and angles in the equations, and there are indications of confusion regarding the relationship between distance traveled and height in the context of gravitational potential energy.
murrskeez
A truck is traveling at 11.1 m/s down a hill when the brakes on all four wheels lock. The hill makes an angle of 15.0° with respect to the horizontal. The coefficient of kinetic friction between the tires and the road is 0.750. How far does the truck travel before coming to a stop? Use energy to solve this problem.
fk = Ef - Ei
fk = μk*FN
FN=mgcos15°
First, I found the work done by the friction force: Wfk = S(μkFN)cos180°
Wfk = μk(mgcos15°)(-1)
Then I solved for the work done by friction using the energy equation:
W = 1/2(mv2) +mgy - 1/2(mvi2) -mgyi
W = 0 + mgy - 1/2(mvi2) - 0
then I set the two equations equal to one another:
μk(mgcos15°)(-1) = mgy - 1/2(mvi2)
the m's canceled out and I solved for y:
y = μk(gcos15°)(-1) + 1/2(vi2) / g
and plugged in values:
y = (0.750)(9.8m/s2)(cos15°)(-1) + 1/2(11.0)2 / 9.8m/s2
and got: y = 6.90 m
knowing that the truck was traveling at 15°, sin15° = y/s
s = 6.90/sin15°
s = 26.7m
the correct answer should be 13.5m. Any help/advice would be much appreciated.
fk = Ef - Ei
fk = μk*FN
FN=mgcos15°
and got: y = 6.90 m
s = 6.90/sin15°
s = 26.7m
Should that 180° angle you used have actually been 15° ?
I thought that the in the formula W = sfcos∅ , the angle ∅ should represent the angle between the direction of s and the corresponding force, which in this case would be friction...and those two directions are 180° apart, right?
Where did s go in your Wfk equation? Also, what is the first equation in the relevant equations section? Don't use y in your potential energy equation, write in terms of s.
Oops, looks like I dropped the s. Looks like that would make
y = sμk(gcos15°)(-1) + 1/2(11.0)2 / 9.8 m/s2
could I then relate s and y through sin? Am I even on the right track?
The first equation is Wother = ΔE , other in this case meaning friction. Was given to me by my professor. But s and y are representing two different things, and y is a reflection of the incorporation of gravitational potential energy into the problem so I don't see how I can get around using it?
Go back a step or two and write out the Wfk=ΔKE+ΔPE equation. Don't use y, use s and θ. Also, keep a close eye on the signs. s is downwards, but both ΔEs should be negative.
Finally got the correct answer, thank you very very much :smile:
You're welcome.
  • · Replies 23 ·
  • · Replies 19 ·
