How Does a Cone's Voltage Affect the Electric Field Near a Grounded Plane?
The discussion centers on calculating the electric field between a cone with a voltage of 100V and a grounded conducting plane. The cone is positioned at an angle of 10 degrees with respect to the z-axis. The method proposed involves using Laplace's Equation in spherical coordinates to solve the problem. The participants confirm the approach is correct and emphasize the importance of utilizing the orthogonality of Legendre Polynomials to solve for the coefficients B_n.
  • Understanding of Laplace's Equation in spherical coordinates
  • Familiarity with electric fields and potentials
  • Knowledge of Legendre Polynomials and their orthogonality properties
  • Basic principles of electrostatics involving grounded conductors
  • Study the application of Laplace's Equation in electrostatics
  • Learn about the derivation and properties of Legendre Polynomials
  • Research methods for solving boundary value problems in electrostatics
  • Explore the concept of electric field calculations near grounded conductors
Students and professionals in electrical engineering, physicists, and anyone involved in electrostatics and field theory who seeks to understand the interaction between charged geometries and grounded planes.
Xyius
The problem gives a cone above a conducting grounded plane. (The xy plane) The cone has a voltage of 100V on it. It wants me to find the electric field between the cone and the plane.
The angle the cone makes with the z axis is 10 degrees. And it is at a height of "h".
So my method for attacking this problem is to use Laplace's Equation in Spherical coordinates. Here is my work.. (I hope you can read my hand writing!)
http://imageshack.us/a/img211/1927/coneproblem.jpg
My question is, is what I have so far correct? And is this the correct approach? Also, how would I go about solving for B_n?? I know that the Legendre Polynomials are orthogonal but what confuses me is, I need to plug in theta=10° into them, thus making them a constant. That leaves me with a function of just r^-(n+1) which (to my knowledge) is not orthogonal.
Any help would be appreciated!
EDIT: Unless there is no "r" dependence either. This would make the problem much easier! But since the cone had a finite height, wouldn't there be an r" dependence?
Yes, your approach is correct. To solve for $B_n$, you need to use the orthogonality of the Legendre polynomials. In particular, you can use the orthogonality relation:$$ \int_{-1}^1 P_n (\cos \theta) P_m (\cos \theta) \, d(\cos \theta) = \delta_{nm} $$where $\delta_{nm}$ is the Kronecker delta function. This will allow you to solve for $B_n$ by integrating over the angle $\theta$.
