Spring Compression problem- PLEASE SOMEONE HELP PLEASE DX<?
The discussion revolves around a spring compression problem involving a 2.4 kg block dropped from a height of 1.7 m onto a spring with a spring constant of 1100 N/m. Participants are exploring the energy transformations that occur during the block's fall and subsequent compression of the spring.
  • The original poster attempts to apply energy conservation principles by comparing kinetic and potential energy at different frames of the block's motion. They question the validity of their approach and seek clarification on the energy terms involved.
  • Some participants clarify the role of potential energy at different heights and the necessity of considering both kinetic and potential energy during the block's fall.
  • Others suggest that analyzing points where the block is motionless simplifies the problem, leading to a clearer understanding of energy conservation.
Participants are actively engaging with the problem, with some providing insights into the correct application of energy conservation. The original poster is beginning to recognize their misunderstanding regarding the energy states of the block during its fall. There is no explicit consensus yet, but productive dialogue is occurring.
Participants are navigating the complexities of energy conservation in a dynamic system, with some confusion regarding the definitions and roles of kinetic and potential energy at different points in the block's motion. The discussion is framed within the constraints of a homework assignment, which may limit the depth of exploration.
Lo.Lee.Ta.
Spring Compression problem!- PLEASE SOMEONE HELP! PLEASE! DX<?
A 2.4kg block is dropped onto a free-standing spring with k=1100N/m from a height of 1.7m above the spring. What is the spring's maximum compression?
Okay, so I drew a picture of the situation.
Frame #1:
Falling Block: kinetic energy, but no potential energy
Spring: No kinetic energy and no potential energy
Frame #2:
Block has now compressed the spring to the maximum it is able.
Block and Spring: potential energy, but no kinetic energy
(If this reasoning is wrong so far, please let me know what is wrong about it and why! Thanks! :D)
So:
Energy in Frame #1 = Energy in Frame #
(Kf + Uf) = (Ki + Ui)
[0 + 1/2(k)(x^2)] = [1/2(m)(v^2) + 0]
([1/2(1100)(x^2)] = [1/2(2.4)(5.77)^2]
x = .2695m
I found the velocity for this equation by: (vf)^2 = (vi)^2 + 2ad
Vf= 5.77m.s
So that was how I found the max. compression of .2695m...
But in class, my teacher got the answer: .29m
He wrote the equation for this problem as: mgh + mgx = 0 + 1/2(k)(x)^2
How does he have 2 potential energies on the left side of the equation?! The block is moving! Wouldn't there be just a kinetic energy?
Please help me! Can the problem be done as I have done it, or is this wrong?
Please explain WHY it is wrong, if that is so.
Thank you SO much! :D You are awesome!
Your teacher observed the block before dropping. In that position his PE was max and his KE was zero. His potential energy is calculated with height that is height of 1.7m above the spring, and the compression of the spring. That means, after the spring compresses, the height of the block changes for height h plus x for the spring compression and therefore mgh + mgx.
Thank you for replying! :)
I think I understand what you mean. The problem ends up being:
(2.4)(9.8)(1.7) + (2.4)(9.8)(x) = 1/2(1100)(x^2)
Only after using the quatratic equation do I get .29, so I get this method...
But it seems to me that my method should have worked also... Because energy is the same throughout a system, but it just gets converted into different forms (kinetic or potential).
So I chose: (1)- when the block was falling- and (2)- when the block had compressed the spring to the maximum it was able.
But I think I see my error now! The falling object would actually have BOTH kinetic and potential energy, right?
That makes it too difficult to analyze, so we instead choose points where the block is motionless.
So my biggest mistake was saying that the falling block only has kinetic energy, when it also has potential energy, right?
Is this reasoning right? Thanks for responding! :)
Exactly. When your block comes to the top of the spring, it has some kinetic energy and potential energy mgx
You could also calculate it the way you started it. You could observe the situation from start to the end of compression. I that situation you would have:
[itex]\frac{1}{2}[/itex][itex]mv^{2}+mgx=[/itex][itex]\frac{1}{2}[/itex][itex]kx^{2}[/itex]
  • · Replies 17 ·
