Polymer with low solar radiation resistance, high heat resistance
The discussion focuses on the design of a solar heating system utilizing a dual-layer structure, where the inner layer is an aluminum alloy water container and the outer layer is a polymer. Concerns were raised about the polymer's susceptibility to UV radiation, which can lead to degradation and brittleness. It was recommended to use commercial solar-grade glass as a more effective outer covering due to its thermal robustness and resistance to sunlight degradation. Additionally, using pipes instead of a large drum was suggested for cost efficiency and improved heat transfer.
  • Understanding of solar heating principles
  • Knowledge of materials science, specifically polymer and metal properties
  • Familiarity with thermal insulation techniques
  • Experience in designing solar energy systems
  • Research commercial solar-grade glass properties and applications
  • Explore the design and efficiency of solar heating systems using pipes
  • Investigate polymer materials with enhanced UV resistance
  • Learn about thermal insulation methods for solar applications
Engineers, students in renewable energy fields, and anyone involved in the design and optimization of solar heating systems.
Syryanyang
I'm an engineer student and I'm trying to build such a solar heating system that it is drum with two layers, inner one is a metal (aluminium alloy I'm thinking) water container and outer layer is made of polymer, with air gap in-between. When suns come out, it radiates through the polymer and on the metal layer, heats up the water inside. The air gap severs as an insulation. Could someone with more experience give me some advice on whether this will work?
why put polymer on the outside? the most common cause of environmental polymer degradation is UV radiation oxidizing the polymer chain ends which then become highly reactive. typically they become brittle and discolored.
if you want an outer covering to prevent convection from carrying away too much heat the best thing to do is commercial solar grade glass since it is thermally robust, doesn't degrade to sunlight and is pretty cheap. also don't take my word for it but i believe its much easier to use pipes instead of one big drum of equal volume since its cheaper to buy pipe than to buy a big steel tank, there's more surface area for radiative heat transfer, and i don't think the extra convective surface would matter with the glass covering.
i've seen some solar heater designs that are just a row of pipes inside an evacuated glass box.
  • · Replies 16 ·
