Schaum's Outline of Quantum Mechanics 8.12
The discussion revolves around determining the most probable value of r for an electron in a hydrogen-like atom, specifically in the state characterized by quantum numbers n and l = n - 1. The participants reference equations from Schaum's Outline of Quantum Mechanics and explore the implications of these equations on the probability distribution of the electron's position.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the radial wave function and the probability density, questioning whether the extremum of the wave function or its square should be used to find the most probable value. There are attempts to reconcile differences between results obtained and those presented in the textbook.
The discussion is active, with participants providing insights and questioning assumptions about the calculations. Some participants express uncertainty about the correctness of their results and the interpretations of the probability distributions, while others offer clarifications regarding the definitions and relationships involved.
There are references to specific equations and examples from the textbook, indicating that the discussion is grounded in the context of assigned homework problems. Participants also mention potential discrepancies between the most probable value and the average value of r, suggesting a deeper exploration of the underlying physics.
Jimmy Snyder
What is the most probable value of r for an electron in the state n, l = n - 1 in a hydrogen-like atom?
Eqn (8.31)
[tex]R_{n, n-1}(\rho) = Ae^{\rho/2}\rho^{n-1}L_{2n-1}^{2n-1}(\rho)[/tex]
Although I have not proved it, I suspect [itex]L_m^m = (-1)^m m![/itex] as in the three cases provided on page 306. That is, L is a constant that can be absorbed into A.
[tex]0 = A \frac{d}{d\rho}Z\rho e^{-Z\rho/2}(Z\rho)^{n-1}[/tex]
[tex]= A \frac{d}{d\rho}e^{-Z\rho/2}(Z\rho)^n[/tex]
[tex]= A (-\frac{Z}{2}(Z\rho)^n + nZ^n\rho^{n-1})e^{-Z\rho/2}[/tex]
[tex]= Ae^{-Z\rho/2} Z^n\rho^{n-1} (-\frac{Z}{2}\rho + n)[/tex]
so
[tex]0 = -\frac{Z}{2}\rho + n[/tex]
or
[tex]\rho = 2n/Z[/tex]
The book has [itex]n^2/Z[/itex]
I tend to believe that the book is correct and I am wrong because according to eqn (8.42) with l = n - 1, the average value of r is [itex](n^2 + n/2)/Z[/itex] and I would expect the average value to be near the most probable value.
You are right about one thing: [itex]L_{2n-1}^{2n-1} (\rho)[/itex] is a numerical constant, i.e. independent of [itex]\rho[/itex].
Shouldn't you be squaring R before calculating its extremal point ? (Check out page 149, point c) from problem 8.5).
Actually, I followed the example of problem 8.5 part c. Note that since [itex]\psi[/itex] is real, the extrema of [itex](\rho\psi)^2[/itex] and [itex]\rho\psi[/itex] are the same. Also note that he uses [itex]\rho\psi[/itex] in his calculations in part c. However, in retrospect, I believe that the author is not correct. The most probable value for [itex]\rho[/itex] is the extremum of [itex]|\psi|^2[/itex] which is the same as the extremum of [itex]\psi[/itex]. In this case I get
[tex]0 = \frac{d}{d\rho}e^{-Z\rho/2}Z^{n - 1}\rho^{n-1}[/tex]
[tex]= (-\frac{Z}{2}\rho + (n - 1))Z^{n - 1}\rho^{n-2}[/tex]
[tex]\rho = \frac{2(n - 1)}{Z}[/tex]
As before, I do not think this result is correct. Do you agree that the most probable value of [itex]\rho[/itex] is the extremum of [itex]P(\rho) = |\psi(\rho)|^2[/itex]?
Your first result is correct; you just need to write it in terms of r now.
[itex]\rho = r/ a_0[/itex], so in units of [itex]a_0[/itex], my result is [itex]r = 2n/Z[/itex]. The answer in the book is given as [itex]r = n^2/Z[/itex] also in units of [itex]a_0[/itex]. However, what do you think about my question in post #3? Did the author make a mistake by finding the extremum of [itex](\rho\psi)^2 = \rho^2P(\rho)[/itex] rather than finding the extremum of [itex]P(\rho)[/itex]?
Also, if my result is correct, why is there such a discrepency between the most probable value of r and the average value of r?
I think you might have looked up the n=2 case for ##\rho##. It's generally defined as ##\rho = 2r/na_0##.
The author is correct. The probability is the product of ##P(\rho)## and the size of the sample space, which is proportional to ##r^2##. For example, for the 1s orbital, the P attains a maximum at the origin, but you're more likely to find the electron away from the origin. The probability of finding the electron at any single point where ##r=a_0## is less than finding it at the origin, but when you sum the probabilities over all points for which ##r=a_0##, the total probability of ##r=a_0## is greater than the probability of finding the electron at ##r=0##.
Thanks vela, I see it now.
  • · Replies 36 ·
  • · Replies 21 ·
