Proving √n Irrational: A Proof by Contradiction
The discussion focuses on proving that the square root of a non-perfect square integer \( n \) is irrational using a proof by contradiction. The proof begins by assuming \( \sqrt{n} \) is rational, expressed as \( \sqrt{n} = \frac{p}{q} \), where \( p \) and \( q \) are coprime integers. The derivation leads to the conclusion that if \( n \) is not a perfect square, then \( p \) must be divisible by \( q \), contradicting the assumption that \( \gcd(p, q) = 1 \). This contradiction confirms that \( \sqrt{n} \) is indeed irrational.
  • Understanding of rational and irrational numbers
  • Familiarity with proof by contradiction
  • Basic knowledge of integers and their properties
  • Concept of greatest common divisor (gcd)
  • Study advanced proof techniques in number theory
  • Explore the properties of irrational numbers in depth
  • Learn about the implications of the Fundamental Theorem of Arithmetic
  • Investigate other proofs of irrationality, such as that of \( \sqrt{2} \)
Mathematicians, students studying number theory, educators teaching proof techniques, and anyone interested in the properties of irrational numbers.
Arkuski
The problem reads as follows:
Let n be a positive integer that is not a perfect square. Prove that √n is irrational.
I understand the basic outline that a proof would have. Assume √n is rational and use a proof by contradiction. We can set √n=p/q where p and q are integers with gcd(p,q)=1. Now n=p2/q2. Next, nq2=p2. This implies p2 is divisible by q2, which subsequently implies that p is divisible by q. If n was a perfect square, its root would be an integer so q=1 and this is satisfied. However, if n is not a perfect square, its root would not be an integer. Thus, p divisible by q shows that gcd(p,q)≠1 and we have a contradiction.
My confusion is with the following step: p2 is divisible by q2 implies that p is divisible by q. Thank you so much for all of the help you can give me.
It's more usual to think about common factors between n and p, and how often they divide each.
  • · Replies 24 ·
