Calculating Kinetic Energy and Work: Practice Problems and Solutions
  • Thread starter Thread starter mark9159
    Physics
This discussion revolves around problems related to kinetic energy, work, and the principles of levers in a physics context. Participants are exploring calculations involving energy transformations and the application of forces in mechanical systems.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are discussing the calculation of kinetic energy for a ball rolling down an incline, questioning the relationship between potential and kinetic energy. There is also a focus on the work done using a lever and the confusion surrounding the application of force and distance in the work formula.
Some participants have provided feedback on the calculations presented, indicating areas of confusion and suggesting corrections. There is an ongoing exploration of the concepts, with participants questioning assumptions and clarifying definitions related to energy and work.
Participants are working under the constraints of homework problems, which may limit the information available for discussion. There are indications of misunderstandings regarding the application of formulas and the interpretation of physical concepts.
mark9159
greetings...i need some help please and someone to check if i did the problems correctly.
1.) How much kinetic energy will a 5kg ball have after rolling down a 1m high incline?
My Answer: 4.43 J
If Potential Energy=mgh, then P=(5kg)(9.81m/s^2)(1m) so P=49.05 J. If this is true, then Kinetic energy = 49.05 J = 1/2mv^2. 49.05=1/2(5)v^2. Then i divided 49.05 by 2.5 (49.05/2.5) which gave me v^2=19.62. I then took the square root of 19.62 which is approximately 4.43 J.
2.) Why are no collisions perfectly inelastic?
My Answer: Almost all collisions involve some rebounding.
3.) A lever is used to raise a 300N rock a distance of 0.6 meters. You must use a force of 75N to accomplish this task. What work is done?
My Answer: 2.45 J
If work can equal mass times gravity times height, then work equals 300N times 0.6 meters, which equals 180. I then did 180 divided by 75N (the amount of force needed), coming up with the solution: 2.45 J
thank you very much for checking my work!
mark
1) After 1m, all potential energy will have been converted to kinetic energy. So your calculation should read:
Ep=Ek
mgh=Ek
Ek=5x9.81x1
Ek=49.05 J
You went the whole way and calculated the velocity, which is measured in m.s^-1. It looks as though you got confused between kinetic energy and velocity.
3) This is quite clearly incorrect. You certainly used more than 2.45 J of energy to lift a 30kg rock from the ground! Read up on levers and you should be able to get this one.
My Answer: 4.43 J
EDIT! Not correct, read scholar's post. Your solution would be correct if
the question was: Calculate the velocity.
I don't know, but your answer sounds good.
My Answer: 2.45 J
That doesn't seem correct. First of all I can see that's not correct because
of the units:
You divided 180Nm=180J by 75N which gives you 2.4m and NOT 2.45J
ALWAYS check the units, it gives you a first hint if your calculation is correct.
so if Work= Force Times Distance, then Work= (75N)(0.6m) which equals 45 Joules...where exactly does the 300N rock come ino the equation?
the problem I am facing is that 45 J is not one of the choices i have to choose from
oh and i really thank you guys for the tip/help..im going to look up more information about levers now.
Mark,
I just send you a private message. I think it's just 300N times 0.6m.
The 75N is the force you need if you use a lever.
Sorry, my fault.
oh, ok. thank you edgardo.
One more question.
What power is required to accelerate a 500kg car from zero to 18 m/s in one minute?
First i found the kinetic energy
Ek=1/2mv^2
Ek=1/2(500kg)(18m/s)^2
Ek=250(324)=81000 J
Power= Joules per second
Power= 81000 J / 60
Power= 1350 W
It takes 1350 W to accelerate a 500kg car from zero to 18 m/s in one minute.
Hello Mark, that seems to be correct.
Regards
Edgardo
  • · Replies 16 ·
  • · Replies 58 ·
