Magnetic field from a current carrying wire + earth's field
The discussion centers on calculating the net magnetic field 20 cm due west of a current-carrying wire with a current of 12.0 A. The magnetic field produced by the wire is calculated using the formula B = (2 * 10^-7) * (12 A / 0.2 m), resulting in a value of 1.2 x 10^-5 T. This field must be combined vectorially with the Earth's magnetic field, which has a magnitude of 5.0 x 10^-5 T and points downward at a 40-degree angle below the horizontal. The final step involves accurately adding these two vector fields to determine the net magnetic field at the specified location.
  • Understanding of Ampère's Law and magnetic fields from current-carrying wires
  • Familiarity with vector addition in physics
  • Knowledge of Earth's magnetic field characteristics
  • Basic proficiency in using the Biot-Savart Law for magnetic field calculations
  • Learn vector addition techniques for combining magnetic fields
  • Study the Biot-Savart Law for calculating magnetic fields from current-carrying conductors
  • Explore the properties of Earth's magnetic field and its variations
  • Investigate the effects of magnetic fields on charged particles
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations.
Jacob87411
A long horizontal wire carries a 12.0 A of current due north. What is the net magnetic field 20.0 CM due west of the wire if the Earth's field there points downward 40 degrees below the horizontal, and has a magnitude of 5.0x10^-5
Unsure on how to start...Do you find the magnetic field produced by the wire and combine it with the Earth's? If so, I did that and found the field produced by the wire to be 1.2 x 10^-5, so how do you combine fields.
But remember that the magnetic field is a VECTOR quantity- that's why they told you that, at that point on the earth, the Earth's magnetic field pointed downward at 40 degree. Assuming that "due west" of the wire means at the same height as the wire, in which direction is the wire's magnetic field pointing? After you have both magnetic fields as vectors, add vectorially.
So 20 cm west of the wire...find the magnetic field from the wire at that point, then add that vectorially with the Earth's..
20 CM due west would mean there is no angle so the magentic field should equal:
B=(2 * 10^-7) ( 12A/.2M)
Then add that vectorially with the Earth's field?
