Can photons be attracted to one another?
  • Context: Graduate
  • Thread starter Thread starter sts107a
    Photons
The discussion centers around the question of whether photons can attract one another, exploring concepts from quantum mechanics, general relativity, and electromagnetic theory. Participants examine the nature of photon interactions, gravitational effects, and theoretical frameworks that might explain such phenomena.
  • Some participants question the meaning of "attraction" in the context of photons, with one suggesting it could refer to a magnetic-like attraction.
  • It is noted that free photons do not interact directly and that any interaction is mediated by other particles, often described as scattering.
  • One participant proposes that gravitational attraction between photons could be considered, but acknowledges the lack of a quantum theory of gravitation to fully address the question.
  • Another participant mentions that while parallel light beams do not attract, anti-parallel beams might exhibit attraction due to their energy density affecting spacetime.
  • Some participants express uncertainty about whether photons can attract each other under general relativity, with references to energy density and the stress-energy tensor.
  • There is a suggestion that light moving through a medium could create currents that attract each other, although this is speculative and contingent on various conditions.
  • One participant emphasizes the importance of discussing photons within the framework of quantum electrodynamics (QED) rather than classical theories like general relativity.
  • Concerns are raised about the complexities of merging classical and quantum theories to explain photon interactions.
Participants do not reach a consensus on whether photons can attract one another. Multiple competing views are presented, with some arguing against the possibility of attraction and others suggesting theoretical scenarios where it might occur.
The discussion includes references to various theoretical frameworks, including general relativity and quantum electrodynamics, and highlights the limitations in current understanding regarding photon interactions and gravitational effects.
sts107a
I just had a quick question; I’m an armature so please excuse my ignorance. But can photons be attracted to one another? And if so how? Thanks for all your help :)
What do you mean "attracted",as in they are beautiful and may fall in love one with another...?
Daniel.
Attracted as in say assort of magnetic attraction.
Sure,electric is outta discussion.Well,free photons DO NOT INTERRACT.Actually photons interact through other particles (their interaction is mediated by other particles),but that is what physicists call SCATTERING...
Daniel.
Ok try this if two frequencies were transmitted from two different transmitters, if they get close enough would they attract one another? In that same case would to photons be attracted to one another
No,classically,the two waves would simply INTERFERE...As for photons,things are more complicated and cannot be put in laymen terms...Definitely not "attraction".
Daniel.
I am presuming you mean "is there any gravitational attraction between photons?" Since photons are quantum objects and there is no quantum theory of gravitation then this cannot be answered with today's physics. However you can ask "do two light beams attract one another." The answer to this is that parallel beams do not but anti-parallel beams do.
asking if photons can attract one another is like asking whether the electromagnetic force can attract itself.
:confused:
I've never worked this out, so forgive me if it sounds dumb, but can't photons attract in GR? I mean, both have energy density and therefore affect the spacetime around them.
That is the context in which I answered above. I forgot to say "according to GR". Photons do not exist in GR but lights beams or light rays do.
Ok but here is what I was thinking. Now I know this is pretty much out of the realm of possibility at this point, but if two photons with the same frequency (I know that one can’t be the other but if it could) couldn’t their same frequencies attracted one another being that it is electromagnetic? And could someone please give me the equation for a photon? I’m having a hard time finding it. Thanks for all your replies
There are no photons in GR,the only theories which account for a decent photon descriptio are the ones in the SM:QED & EW.In both theories,photons do not interact.They scatter one on another via particle +antiparticle fields.
GR is a very classical theory.Einstein-Maxwell and Kaluza-Klein are both classical models.
Daniel.
sts107a said:
but if two photons with the same frequency couldn’t their same frequencies attracted one another being that it is electromagnetic? And could someone please give me the equation for a photon? I’m having a hard time finding it. Thanks for all your replies
Frequency are numbers.Physical quantities measured in [itex]Hz[/itex].How can they ATRACT...? :rolleyes:
Daniel.
While the educational answer should be a clear "No they don't interact"
there are the ever so small effects.
The standard ones:
1) GR: everything which has energy "attracts" anything which has energy.
2) QED: higher energies or smaller scales cause more interaction with virtual particles.
But I can also imagine the following effect:
Light moving through a dielectricum causes currents at a 90 degrees phase
shift with respect to the electric field. Parallel currents do attract each
other even if it's at a ratio of (v/c)2 where v is generally very small.
This might even be extended to the dielectricum of the vacuum if it's
interpreted as vacuum polarization which is in general attributed to virtual
particles. The amount of current is then expressed by the usual dD/dt from
Maxwell. The dD/dt would cause the effect to be more significant at higher
frequencies: light, x-ray, gamma photons...
I could imagine that such an effect could lead to the compactification of
wave packets in the direction transversal to the propagation, or at least
to less spreading.
Regards, Hans.
Let's keep the discussion within the theoretical framework which accounts for photons:equilibrium statistical mechanics in second quantization and QED.
I think reference towards classical theories (such as GR & CED) is of no relevance.
And EW will not bring anything new in photon/quantized QED description...
Daniel.
I was under the same impression, though i am not sure. However if we have a particle (we don't need to call it a photon) that has an associated energy-density of some kind (it does not matter whether this energy comes from restmass or dynamical mass generation-processes like in the photon-case), then space time must be curved right ?
In the end it is the stress energy tensor that curves space time not just the rest-mass...This notion is adopted by QFT where the perturbations (you know, the "current" in QFT-language) of a spin 2 field is expressed by this stress-energy tensor T.
This field needs to be spin 2 (the gravitons) because otherwise it cannot couple to the stress energy tensor which is a symmetric tensor with two indices and has therefore 5 degrees of freedom.
So TOM, i think you are quite right on this one
marlon
I am afraid the question is more complicated. After reading a comment in this thread, I searched about this subject and found this: http://arxiv.org/gr-qc/9811052 . There it is shown that two parallel light beams do neither attact nor repel, since their gravitoelectric field cancels their gravitomagnetic field. (If you want to avoid the whole calculations go directly to chapter 4). In case of antiparallel light beams there is indeed an attraction.
This concerning light beams. Now, it seams to me that the question about single photons might be more subtle. They are always moving at speed c, and their gravitational field should also propagate at that speed. Consider for example two parallel photons. Will one photon feel the gravitational field of the other one? In case of photons moving towards each other, they probably will. I wonder how to figure out the bending of spacetime produced by a photon.
Well, we need to know the actual formula for the stress energy tensor in the specific case of a photon. If it is zero, then there is no curvature of spacetime.
According to me we need to know how this energy tensor looks like in the case of a photon. Does anyone know this ?
marlon
Marlon,are u trying to "assemble" classical GR with quantum electrodynamics...?
If u succeed,then the Nobel for 2005 may be yours...:wink:
Daniel.
Daniel.
No i am not.
QFT is able to prove that masses attract. This can be done with the "simple" path integral quantization formalism. Just replace the J-terms by the stress energy tensor.
marlon
Read Anthony Zee's QFT in a nutshell. This is done in the first or second chapter...
Okay,let's stick it to QED,then and leave GR alone...
Daniel.
  • · Replies 29 ·
  • · Replies 33 ·
  • · Replies 27 ·
  • · Replies 32 ·
  • · Replies 38 ·
  • · Replies 0 ·
