Optimizing n for ε in a Square Root Expression
  • Thread starter Thread starter peripatein
    Expression
The discussion revolves around finding a suitable value of n such that the expression |sqrt(n^2+3)-sqrt(n^2-1)| is less than ε for all n greater than a certain threshold n0. The problem is situated within the context of limits and approximations in calculus.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore different methods to simplify the expression, including reformulating it and squaring both sides. There is a focus on the implications of ε being greater than 1 and the conditions under which certain approximations hold.
Several participants are actively engaging with the problem, questioning the assumptions about ε and discussing the validity of their derived expressions. Some guidance has been offered regarding the neglect of certain terms for small ε, but there is no explicit consensus on the best approach or final expression for n0.
Participants note that the problem states ε is positive, leading to discussions about its potential values, including larger numbers like 40, and how this affects their calculations and assumptions.
peripatein
Hello,
Is there a better way to find n such that for every n>n0 |sqrt(n^2+3)-sqrt(n^2-1)|<ε?
I have tried reformulating the expression on the left side so that only one of the square roots remains, to not much avail. The only way I could solve it was by squaring both sides. I did get the correct expression for ε for every ε<1, but it does not work for larger ε's, hence, alas, it is wrong.
Any word of advice, please?
peripatein said:
Hello,
I don't see why you would need to worry about ##\epsilon## ≥ 1. In fact, you should probably be able to assume that ##\epsilon## < 1 - the whole goal of this exercise is to show that you can choose n large enough so that the difference of the two square roots is arbitrarily small.
Thank you very much for replying.
n0 >= sqrt(epsilon^4-4epsilon^2+16)*1/(2epsilon)
Which not only seems very messy but also yields wrong results for epsilon greater than 1. The question states that epsilon is positive, so I presume my expression must hold for any epsilon, even if greater than 1.
I know that the right answer should probably be 1/(2epsilon), but how may I derive it?
My bad, I meant that the right answer should probably be 2/epsilon!
If ##\epsilon## is suitably small, then ##\epsilon^4## and ##\epsilon^2## can be neglected. This makes the expression on the right side approximately equal to √16/##2\epsilon##, which gives you the (corrected) result below.
I know that the right answer should probably be (edit: corrected from later post) [STRIKE]1/(2epsilon)[/STRIKE] 2/##\epsilon##, but how may I derive it?
But what if epsilon were equal to 40? In that case epsilon^4 and epsilon^2 may not be neglected and 2/epsilon still yields the right value for n0, whereas sqrt(epsilon^4-4epsilon^2+16)*1/(2epsilon) doesn't!
Why would anyone care? ##\epsilon## is almost always used to represent small (close to 0) numbers.
Since that is a decreasing function of n, and is 2 when n= 1, as soon as [itex]\epsilon[/itex] is larger than 2, you can take [itex]n_0= 1[/itex].
  • · Replies 22 ·
