Electro question: Drop Voltage with 1 ohm resistors
To drop the voltage from 6V to 4V using 1 ohm resistors, connect three 1 ohm resistors in series. This configuration creates a voltage divider where the voltage drop across two of the resistors will equal 4V. The total current flowing through the circuit will be 2 Amps, as determined by Ohm's Law (V=IR). It is essential to understand that the potential difference of the battery remains at 6V, but the voltage across the specified resistors can be utilized as a new voltage source.
  • Understanding of Ohm's Law (V=IR)
  • Basic knowledge of series and parallel resistor configurations
  • Familiarity with voltage dividers
  • Concept of current flow in electrical circuits
  • Study voltage divider circuits in detail
  • Learn about series and parallel resistor combinations
  • Explore practical applications of Ohm's Law in circuit design
  • Investigate the effects of load on voltage drop in resistive circuits
Electronics enthusiasts, electrical engineering students, hobbyists designing circuits, and anyone interested in understanding voltage regulation using resistors.
atrain77a
This might be a silly one, but I'm a bit stumped:
Suppose you have a 6V battery and an unlimited supply of 1 ohm resistors.
How do you drop the potential from 6V to 4V using the resistors?
Off the top of my head I think you just put two of the resistors into a series attached to the positive side (cathode??) of the battery and you're at 4V.
However, since current isn't mentioned anywhere (think V=IR) I'm a bit confused. Is it possible to simply lower potential by stringing resistors together in series without worrying about current drawn or did I miss something simple? Thanks a bunch. -Stumped T. Day
Current is only created in the presence of a potential difference and resistance, so they didn't mention it because without the resistors you have no current. With resistors in series the current is the same, I = I1=I2=... also, so it will be constant. If they are in parallel than I=I1+I2... and the voltage stays the same.
You should be able to use that to construct a circuit that has a final potential difference between two points of 4V. The potential difference between your battery though will always be 6V.
Also just to make sure you know, to get current or resistance in a circuit you must have a potential difference, so if you have two resistors hooked up to the + battery terminal nothing will happen.
A simple voltage divider will do. Connect 3 1 Ohm resistors in series, the voltage drop across two 1 ohm resistors will be 4 Volts (you can verify this using Ohm's Law). You can use this potential as your new 'battery' (Although in practice, I would recommend this configuration since 2 Amps are flowing through the circuit).
Claude.
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 28 ·
17K
