Does a Nullspace Spanned by the Zero Vector Indicate Its Dimension Is Zero?
The discussion confirms that if the nullspace of a matrix is spanned by the zero vector, its dimension is indeed zero. Both matrices A and B, which are 3x3 and reduce to the identity matrix, have a nullspace dimension of 0, indicating that there is a pivot in every column. Consequently, the dimensions of the column spaces dim(Col(A)) and dim(Col(B)) are both 3, confirming that these matrices map nonzero vectors in R3 to other nonzero vectors.
  • Understanding of nullspace and column space in linear algebra
  • Familiarity with matrix transformations and their dimensions
  • Knowledge of identity matrices and their properties
  • Basic concepts of vector spaces and linear mappings
  • Study the properties of nullspaces in linear transformations
  • Learn about the Rank-Nullity Theorem and its implications
  • Explore examples of matrices with non-trivial nullspaces
  • Investigate the relationship between row space and column space
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators teaching concepts related to matrix theory and vector spaces.
charlies1902
I am a little confused about dimensions, if the nullspace of a matrix is spanned by the 0 vector, does that mean the dimension of the nullspace of this matrix is 0?
In the problems I attached, both A and B reduced to the identity matrix.
Note (2) is supposed to be dim(N(B)) and dim(col(B)) instead of dim(N(A)) and dim(col(A)).
Since they both reduce to I, that means a pivot is in every column, which means that the dimension of N(A) and N(B) is 0 right?
Consequently, this means dim(Col(A)) and dim(col(B)) is 3 right?
Yes.
Right.
Yes.
Let's look at this situation from the perspective of transformations. Your matrices are 3 X 3, meaning that they represent transformations from R3 to R3 (or possibly a lower dimension subspace of R3). Since both matrices reduce to I3, both matrices map a nonzero vector in R3 to some other nonzero vector. The only vector mapped to <0, 0, 0> is the zero vector itself. Another way to say this is N(A) = N(B) = {0}.
If it had turned out that the nullspace for one of the matrices was one-dimensional, then some vectors in R3 are getting mapped to 0. For this matrix, the range would be a two-dimensional subspace of R3. In other words, a plane embedded in space. An example of this is T(<x, y, z>) = <x, y, 0>. This transformation projects a vector v down to the x-y plane.
  • · Replies 24 ·
