Thread Closed
Manufacture of nitric acid
Share Thread Thread Tools
Feb24-05, 09:11 AM   #1
k3l
from a series of reactions
i got the formula which produces [tex]HNO_3[/tex]... the "result" formula is:
[tex]4N_2_(_g_) + 6H_2_(_g_) + 8O_2_(_g_) -> 4HNO_3_(_a_q_) + 4H_2O_(_l_)[/tex]
The question asks to find the weight of nitrogen,
and the Volume of nitrogen (at STP) required to produce 5.00 kg pure nitric acid.
what i want to know is what does it mean by the weight of nitrogen?
thx
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Scientists make breast cancer advance that turns previous thinking on its head
>> Cradle turns smartphone into handheld biosensor
>> New filtration material could make petroleum refining cheaper, more efficient
Feb24-05, 09:41 AM   #2
Admin
Quote by k3l
Literally - weight of the nitrogen used. I suppose if it was a solid you will have no problems? So do it exactly the same way as if [tex]N_2[/tex] was solid.
And don't forget that 1 mole of gas at STP has volume 22.4 l.
Best,
Borek
http://www.chembuddy.com
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Feb24-05, 11:57 AM   #3
Recognitions:
Homework Helper Homework Help
"Weight+chemistry=mass".Don't take it literally or as something axiomatic....
Daniel.
Feb24-05, 01:25 PM   #4
Admin
Quote by dextercioby
"Weight+chemistry=mass". Don't take it literally or as something axiomatic....
Now that you pointed at, it is obvious
The funny thing is I will never mix these things in Polish
Best,
Borek
Feb24-05, 01:46 PM   #5
Recognitions:
In physics "weight" has other sense.Chemists are making their own rules.
Daniel.
Mar3-05, 09:27 PM   #6
Quote by k3l
thx
That "formula" may describe the overall ratio of the elements involved, but it's NOT how HNO3 is made. Industrially, it's made by the catalytic oxidation of N2 to nitrogen oxides, which are dissolved in H2O to produce a mixture of HNO3/HNO2. The HNO2 is then oxidized to HNO3 with O2 from air. In the lab, HNO3 is made by heating a nitrate with H2SO4 and distilling off the vapor. But, you DON'T NEED the reaction formula to answer that question! You just need to calculate the number of moles of N in 5 kg of HNO3. Half that number will be the moles of N2 needed, and the volume is found by V = n*R*T/P
Mar8-05, 02:13 PM   #7
isnt the volume occupied by 1 mole of gas: 24dm3 at 298K, and 22.4 at 293K?
Mar8-05, 05:27 PM   #8
Quote by k3l
thx
Listen to pack_rat2. You don't need the overall reaction because the only source of nitrogen in nitric acid is atmospheric nitrogen, or N2. 1 mole of nitric acid is made by half a mole of nitrogen.
Weight of nitrogen = 0.556 kg
Volume of nitrogen = 889 litres
Thread Closed
Thread Tools
Similar Threads for: Manufacture of nitric acid
Thread Forum Replies
manufacture of bromine Biology, Chemistry & Other Homework 6
Simple Chemistry: Nitric Acid Biology, Chemistry & Other Homework 14
Nitric acid equation!! Biology, Chemistry & Other Homework 1
Nitric acid from gasoline Chemistry 1
