Calculating Electric Potential at a Point
The problem involves calculating the total electric potential at a specific point due to multiple point charges arranged in a rectangle. The charges and their values are provided, along with the distance from the charges to the point of interest.
  • Participants discuss the cancellation of certain charges and the method of calculating electric potential using the formula provided. There are questions about the distance used in calculations and the validity of the resulting potential value.
Some participants express confidence in the calculations presented, while others question the units and the interpretation of the results. There is a general exploration of potential discrepancies in the problem setup rather than a consensus on a solution.
Participants note potential issues with the homework assignment program's feedback and the interpretation of charge values, as well as the implications of using microcoulombs in calculations.
swrs92
I'm fairly certain I'm doing this problem right.. But my homework assignment program keeps telling me it's incorrect..
The drawing shows six point charges arranged in a rectangle. The value of q is 6.78 μC, and the distance d is 0.15 m. Find the total electric potential at location P, which is at the center of the rectangle.
http://imgur.com/YsSCB
Associated picture
Electric Potential = Ʃ(kq/r)
So basically, since the +5, -5, +3, -3 charges cancel out, i ignore them. I pretty much plug in (2*7q)/r.
I end up with 5.09*10^6 V.
I don't know what I'm doing wrong.. Can you please let me know whether or not this is the correct answer based on the numbers I provided, and if not, suggestions as to where I went wrong.
Thank you,
Associated picture
Thank you,
What did you use for r?
Using the Pythagorean (spelling?) theorem, I got 0.1677m (sqrt(0.15^2 + 0.075^2))
Any insight?
Your calculations all look correct to me. But I'm no electrostatics expert, so I might be missing something wrt units. Millions of volts seems like a big answer, but maybe a microC is a big charge.
Thanks!
Like I said, I'm fairly certain that the issue is with the question as opposed to my work. I tried googling a similar problem online, I used their numbers with my reasonings and I got the right answer
The method looks good, and I got the same answer.
That's good to hear I guess ahah, thanks for your help guys
  • · Replies 22 ·
