Metal-semiconductor junction with p-type and n-type and varying work functions
The discussion revolves around the energy band diagrams associated with metal-semiconductor junctions, specifically focusing on both p-type and n-type semiconductors. Participants explore the implications of varying work functions of metals and semiconductors, considering cases where the work function of the metal is greater than or less than that of the semiconductor. The conversation includes technical aspects of band bending and charge carrier behavior in these junctions.
  • One participant describes their understanding of energy band diagrams for n-type semiconductors and expresses uncertainty about the Fermi level in p-type cases, suggesting that holes are the charge carriers and that a depletion region exists when the metal work function is less than that of the semiconductor.
  • Another participant agrees with the initial diagrams but challenges the representation of holes in the p-type case, suggesting that it is more appropriate to refer to electrons instead, and provides guidance on how the band bending should appear.
  • A different participant comments on the limitations of band diagrams for Schottky contacts, arguing that they do not accurately reflect contact potentials derived from work functions and doping levels, and suggests positioning the Fermi level near the conduction or valence band to improve the diagrams' validity.
  • This participant also proposes a novel experimental approach involving metal contacts to inject holes into silicon without doping, referencing previous work on silicon superconductivity and suggesting potential tests involving heterojunctions with p-doped GaP.
Participants express differing views on the representation of charge carriers in the band diagrams and the implications of work function differences. There is no consensus on the best approach to depict the energy band diagrams for p-type semiconductors, and the discussion remains unresolved regarding the accuracy of the proposed diagrams and the theoretical implications.
Participants acknowledge the complexity of Schottky contacts and the challenges in accurately representing band diagrams. There are references to specific experimental conditions and theoretical scenarios that may not be universally applicable.
mitch_1211
Hi All,
I am trying to get my head around the energy band diagrams associated with forming a metal-semiconductor junction for both p and n type s/c. I am also consider for each type, the case of [itex]\phi[/itex]m > [itex]\phi[/itex]n (work function of metal greater than work function on s/c) and [itex]\phi[/itex]m < [itex]\phi[/itex]n (work function of metal less than work function of s/c).
I have come up with energy band diagrams (attached) for both cases with n-type s/c. The left shows both materials separated in a vacuum, and the right shows the bending of the bands when combined and under thermal equilibrium.
I have drawn partially the case of p-type with [itex]\phi[/itex]m < [itex]\phi[/itex]p with what I believe to be the correct bending of the bands.
However I am unsure where the Fermi level should equalise to for the p-type cases. I *think* that the charge carriers here are holes and as such there is a depletion region for [itex]\phi[/itex]m < [itex]\phi[/itex]p.
Any guidance in terms of drawing the band diagrams for both p-type cases would be much appreciated!
anyone?
You seem to have the correct picture for the first two diagrams in terms of the flow of carriers and the direction band bending. In the third diagram, however, it doesn't make sense to talk about flow of holes. Since in the metal there is no electronic excitation gap it does not make sense to talk about holes. The part where you drew an arrow from the metal to the p-type semiconductor you should replace the "h" with an "e." In this diagram, the band bending would look like the one in the second figure. Note that the side which has a positive charge has a lower vacuum level. Now, in the fourth diagram (which you did not draw) for the ##\phi_m > \phi_p## case, the band bending would look like the first diagram and your valence band would cross the Fermi level (similar to how the conduction band crosses the Fermi level in the second diagram).
thanks so much for clearing that up, really appreciate the time you took to draw the diagram as well :)
My two cents worth of comments...
Schottky contacts are always dirty. Band diagrams work badly for them. You don't get (by far) the contact potentials estimated from work functions, doping etc.
Putting the Fermi level near the conduction (in N type) or valence band (in P type) would make the diagrams more convincing, as this would impose to bend the bands.
I don't know if you can get the metal's level outside the gap. Metals and semiconductors exist that should do it, but I haven't heard of such a practical case.
I suggested to use such a situation (metal below valence band, 3rd diagram of 1st drawing) to inject a huge density of holes into silicon using - was it platinum, tungsten...? This would be a new test for silicon superconduction. The first was obtained (at Orsay, hi there) by brutal P overdoping of silicon and cooling to few mK. A metal contact would bring the carriers without the dopant, hence keep true silicon instead of a 10% boron alloy... Better: said metal does not become a superconductor (at least when it keeps its holes).
An other superconduction test in silicon would involve a heterojunction with P-doped GaP which, from its wider gap, would also inject dense holes in silicon without dopant there.
I suggested it few years ago on a forum, no idea if this was made meanwhile.
Marc Schaefer, aka Enthalpy
  • · Replies 0 ·
