Complex Vector Space Analogy To Quantum Mechanics
The discussion revolves around the use of complex vector spaces in quantum mechanics, exploring the definitions, intuitions, and implications of this mathematical framework. Participants express confusion about the nature of vectors in quantum mechanics, the operations performed on them, and the relationship between complex and real vector spaces.
  • One participant questions the rationale behind using complex vector spaces to describe quantum states and seeks basic intuition about the mathematics involved.
  • Another participant asks if the original poster has studied linear algebra, implying that understanding this subject is crucial for grasping the concepts discussed.
  • Some participants express uncertainty about what constitutes "real vector operations" and how they relate to abstract vectors.
  • A participant mentions the historical context of quantum mechanics, noting that initial experiments did not fit conventional rules until a connection to vector mathematics was observed.
  • Another participant suggests that complex vector spaces are necessary for certain mathematical transformations and theorems, such as Wigner's theorem, which do not hold in real vector spaces.
  • One participant reflects on the surprising utility of the mathematical concept of imaginary numbers in describing physical phenomena, expressing discomfort with the abstraction.
  • Several participants discuss the definition of vector spaces, emphasizing that complex vectors are still considered vectors by definition, and that the operations performed on them adhere to the same rules as traditional vectors.
  • A participant notes the transition from finite-dimensional vectors to infinite-dimensional wave functions, which also conform to vector space axioms.
Participants generally express a lack of consensus on the nature and implications of complex vector spaces in quantum mechanics. While some gain intuition about the topic, others remain confused about the relationship between abstract vectors and traditional vector operations.
Some participants mention the need for a solid understanding of linear algebra and vector space axioms to fully grasp the discussion. There are references to historical developments in quantum mechanics that may not be universally understood among participants.
CrazyNeutrino
Guys I am having a little trouble understanding how and why we use complex vector spaces
to describe the quantum states of a particle. Why complex vector spaces, and how is a complex vector space defined. Also are the 'vectors' in the field of quantum mechanics simply elements of a vector space like real numbers, or are the vectors actually analogous to actual vectors. Leonard susskind at Stanford already said that they are ONLY elements of a set of elements but i don't seem to understand how we can do STANDARD vector operations if they are not STANDARD vectors and are only ABSTRACT vectors. Can someone please help me with basic intuition behind the mathematics of quantum mechanics.
Have you studied linear algebra?
Yeah, but I haven't learned complex vector spaces and how can we perform real vector operations on abstract vectors?
I am not sure what you mean by "real vector operations." Did you take the definition of "vector space" in linear algebra?
Did you study mathematics in high school ? If so, then the curriculum ought to have included that bit of abstract algebra in which you had to show that the set of complex numbers endowed with 2 internal operations (addition & multiplication) is a field.
I struggled with this concept for a while.
I guess you can say it's because the math works.
It's a bit like fitting a curve to some experimental points. If you notice they form a sort-of-straight-line you can draw a line and say that's it.
Initial QM experiments (on spin) gave results that didn't fit any obvious rules until someone noticed that the behaviour appeared to parallel vector maths with a few 'i's thrown in..
Using vector calculations on the phenomena at least gives the right answer even if we can't find a real vector to justify it.
Why QM uses complex vector spaces is a deep issue, but without going into the details its got to do with the necessity of infinitesimal transformations from, for example, an infinitesimal displacement of the measurement apparatus, which can be shown to require complex rather than real vector spaces, if you want, for simplicity, such transformations to be linear. Another reason is some really nice theorems such as Wigners theorem only work in complex spaces.
But over and above that in applied math the eigenvalue problem often arises (eg in Markov Chains) and generally, even if you start with real numbers, complex numbers tend to creep in because, in general, eigenvalues and eigenvectors are complex.
The elements of a complex vector space are just as much vectors as those in a real vector space - its by definition.
Thanks
Bill
It's interesting that the apparently artificial mathematical concept of the square root of a negative number should turn out to be a 'solid' part of the real world.
I find the fact that we can invent such a crazy idea and then find that it fits into the physical world somewhat disturbing.
Most mathematical ideas are based on some conceptual model of a 'real' process. But 'i' ? We just dreamed that up for a laugh surely?
Thanks Guys... I am kinda getting an intuition on why complex vector spaces are used instead of real ones. But i think its really weird that operations that you would do with classical vectors or pointers work with elements of a set.
Not really - after all, you defined it as a set of vectors.
I think the point is, that a vector space is defined as a set and some operations defined on the set, which in the end obey the same rules as the "traditional" vectors. Actually i had to prove/disprove the vector space axioms for lots of sets and associated operators in school and again at the university.
Especially in the case of "complex vectors" like in QM, which are simply vectors where the elements are complex numbers, i think that iss easy to show and understand. (Just find the required axioms for a vector space on wikipedia and plug in the definition of your hilbert space vectors and the operations on them and see that the axioms work out).
If now you go from vectors with finite dimensions (=="elements") to vectors with infinitely many dimensions, you get the usual wave-functions, which also obey the vector space axioms, though it might be slightly harder to show.
  • · Replies 16 ·
  • · Replies 61 ·
