The discussion centers around the use of NTC thermistors (50, 100, 250 ohms) for controlling LED light output based on temperature changes. Participants explore wiring configurations, current limitations, and potential issues with the setup.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant describes attempts to wire thermistors with LEDs using both series and parallel configurations, noting issues with the series configuration and overheating in the parallel setup.
- Another participant suggests measuring the thermistor's resistance with an ohmmeter and using a voltage divider with a small current (1 mA or less) to avoid self-heating effects.
- A different participant emphasizes that exceeding 1 mA can render the setup ineffective due to self-heating, which obscures ambient temperature changes.
- One participant clarifies that the LM35 mentioned is not a thermistor but an integrated circuit designed for temperature measurement, providing additional context about its use.
- Another participant expresses frustration over the inability to get the thermistors to respond, questioning their functionality.
- A later reply asserts that the participant's approach is fundamentally flawed and suggests using a transistor amplifier driven by the thermistor to control the LED, while also emphasizing the importance of understanding current limits.
- One participant reiterates the distinction of the LM35 as an IC, sharing appreciation for its design and functionality, while acknowledging a sidetrack in the discussion.
Participants express differing views on the effectiveness of the current setup and the proper method for using thermistors. There is no consensus on the best approach to wire the thermistors or on their functionality.
Participants mention limitations regarding current levels and the potential for self-heating effects, but do not resolve the underlying issues with the thermistor setup or the specific configurations attempted.
