Question involving work and springs
  • Thread starter Thread starter mldavis086
    Springs Work
The discussion centers on a physics problem involving Hooke's law and work done on a spring. A 4.00-kg object stretches a spring by 2.50 cm, leading to the calculation of the spring constant (k = 1568 N/m). When a 1.50-kg block is hung on the same spring, it stretches by 0.938 cm. For the work done to stretch the spring 4.00 cm, the user initially calculates 2.51 J but realizes the need for integration due to the non-constant force, with the correct answer being 1.25 J based on the spring's potential energy formula.
  • Understanding of Hooke's Law (F = -k*x)
  • Knowledge of work-energy principles (W = F*x)
  • Basic calculus for integration of variable forces
  • Familiarity with potential energy in springs
  • Study the derivation of the spring potential energy formula (U = 1/2 k x^2)
  • Learn about the integration of forces in physics problems
  • Explore advanced applications of Hooke's law in real-world scenarios
  • Review examples of work done on non-constant forces
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of Hooke's law and work-energy principles.
mldavis086
When a 4.00-kg object is hung vertically on a certain light
spring that obeys Hooke’s law, the spring stretches 2.50 cm.
If the 4.00-kg object is removed, (a) how far will the spring
stretch if a 1.50-kg block is hung on it? (b) How much
work must an external agent do to stretch the same spring
4.00 cm from its unstretched position?
F = -k*x
W = F*x
**I get a) correct so you can skip to b) if you want
a) First using the 4kg block I get a force of 39.2N. Then using 39.2 = -k*-0.025 and solving for k I get k= 1568 N/m. .
Then inputting k for the 1.5 kg block(F=14.7 N) I get 14.7=1568x. x=0.00938 m or x= 0.938 cm
b)This is what I tried to do: F=-1568*-0.04=62.8 N So the force needed is 62.8 N. So using W=F*x, I get W= 62.8*0.04 = 2.51 J
I can see in the back of the textbook the answer is 1.25 J, so I'm tempted to just divide my answer by 2 but then I won't understand why. Can anyone out there explain this to me please??
The force is not constant as the spring is stretched, so you need to integrate. Alternatively, if you know the formula for spring's potential energy, you could just use that.
  • · Replies 17 ·
  • · Replies 18 ·
