Calculating optimum thickness of the insulation for composite wall
The discussion focuses on calculating the optimum thickness of insulation for a composite wall consisting of wood and concrete. The total thickness is fixed at 10 cm for concrete and 1 cm for wood, with thermal conductivities of 1.0 W/mK for concrete and 0.1 W/mK for wood. The objective is to minimize heat leakage into the room by optimizing the placement of the wood within the concrete. The solution involves understanding thermal resistance rather than using derivatives to find a minimum value.
  • Understanding of thermal resistance concepts
  • Knowledge of heat transfer principles
  • Familiarity with material properties, specifically thermal conductivity
  • Basic calculus for optimization (though not strictly necessary for this problem)
  • Research methods for calculating thermal resistance in composite materials
  • Learn about the impact of material placement on heat transfer
  • Explore practical applications of insulation in building design
  • Study optimization techniques in thermal systems
Students in engineering or architecture, thermal system designers, and professionals involved in building insulation and energy efficiency optimization.
onquest
A wall is required to be insulated by embedding wood within concrete. the total thickness of the concrete and wood are 10cm and 1 cm respectively and are fixed due to structural constraints. determine the minimum heat leak into the room if the location of the wood can be changed within the concrete. Take K for wood as 0.1w/mk and for concrete 1.0w/mk
Please help.
thermal resistance
I tried solving using thermal resistance concept by equating derivative of the total thermal resistance to 0, but not able to get the answer.
I don't believe they are asking you to find the minimium of an equation (eg I don't think you need to use derivatives). When they use the word minimium I think they are just referring to the fact that their might be other ways for heat to get into the room other than by conduction but these are to be ignored.
  • · Replies 27 ·
