How Do You Describe a Cylinder Using Spherical Coordinates?
  • Thread starter Thread starter Mdhiggenz
    Cylinder
The discussion revolves around describing the cylinder defined by the equation x² + y² = 9 using spherical coordinates (ρ, θ, φ). Participants are exploring how to express the parameters in relation to the geometry of the cylinder.
  • Participants are attempting to relate the spherical coordinates to the cylindrical equation, with some confusion about the interpretation of the parameters, particularly the role of ρ (or P) in the context of the cylinder's geometry.
The discussion is ongoing, with participants clarifying the definitions of the parameters involved and questioning the assumptions made about the relationship between the coordinates. Some guidance has been offered regarding the geometric interpretation of the cylinder and how to relate z to spherical coordinates.
There is a noted confusion regarding the use of ρ as the distance from the origin versus its relationship to the radius of the cylinder. Participants are also considering the implications of slicing the cylinder with planes to visualize the problem better.
Mdhiggenz
Describe the cylinder x2+y2=9
in terms of parameters theta and phi, where (p,theta,phi) are spherical coordinates of a point on the surface.
I'm a bit confused I know that spherical coords are
x=Psin(phi)cos(theta)=3sin(phi)cos(theta)
y=Psin(phi)sin(theta)=3sin(phi)sin(theta)
z= Pcos(phi)=3cos(phi)
But the answer is way off it's
x = 3 cos(theta) ; y = 3sin(theta) ; z = 3 cot(phi)
In your third equation you're thinking that P is the radius of the circle.
Slice the the cylinder with a plane containing X and Z axes and you'll see two vertical lines so a point on the cylinder is a vector from the origin to the point which makes a triangle with the P being the bottom side and the z value being the vertical side .
Now describe Z in terms of spherical coordinates phi angle.
Not really sure what you mean?
your eqn is a cylinder along the z axis, right?
So if you slice the cylinder with a plane containing the X and Z axes you'll see two vertical lines at x=3 and x=-3, right?
Indeed
jedishrfu is pointing out that there is some confusion regarding p (or P).
In the problem statement, p is the distance from the origin to a point on the cylinder. You have used P as the radius of the cylinder (=3). A point on the cylinder may be further than 3 from the XY plane, so z cannot be given by 3 cos(phi).
[itex]\rho[/itex], what you are calling "P", is the straight line distance from the origin to the point, (x, y, z). It is NOT [itex]\sqrt{x^2+ y^2}[/itex], the distance, in the xy-plane, to the projection (x, y, 0).
From [itex]x= \rho cos(\theta)sin(\phi)[/itex] and [itex]y= \rho sin(\theta)sin(\phi)[/itex], you can get [itex]x^2+ y^2= \rho^2 cos^2(\theta) sin^2(\phi)+ \rho^2sin^2(\theta)sin^2(\phi)= \rho^2sin^2(\phi)[/itex].
