New Reply
Conservation of momentum continous mass flow freight cart.
Share Thread Thread Tools
Nov5-12, 04:32 PM   #1
I am having difficulty understanding why in 2.1 Worked Example Coal Car on page 3 One can use the initial time as time = 0, but 2.2 Worked example on page 4 they start the initial time at an arbitrary time t.
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov5-12, 04:36 PM   #2
because in the second example if you start with the initial time =0 then the initial momentum is zero because it is initially at rest and this simplifies the second example to a solutions similar to the first. But that is wrong.
Nov6-12, 03:04 AM   #3
Recognitions:
Homework Helper Homework Help
your two links point to the same page, and I can't see anything there that matches either description.
Nov6-12, 09:57 AM   #4
Thank you I put up the wrong link. Here is the correct link:
Nov6-12, 03:42 PM   #5
Recognitions:
In each case they start at t=0. In 2.2 they also consider some arbitrary later time t and an interval δt from there. That is normal when deriving differential equations. In 2.1 they did not need to do that; they could solve the problem just by considering t=0 and t=tf and applying conservation of momentum. Whether such an approach was available in 2.2 I've not tried to analyse.
New Reply
Thread Tools
Similar Threads for: Conservation of momentum continous mass flow freight cart.
Thread Forum Replies
mass flow through pipe (conservation of mass) Engineering, Comp Sci, & Technology Homework 0
Conservation of mass/flow through tanks Engineering, Comp Sci, & Technology Homework 1
Cart-Cart Collision, Conservation of Momentum Introductory Physics Homework 3
Collision:child jumps on moving cart, cart slows down, find mass of the cart, impulse Introductory Physics Homework 1
Child jumps on a cart, cart slows down, find mass of the cart and thrust force Introductory Physics Homework 3
