Integration with branch cuts and singular points
The integral \(\int_0^{\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx\) evaluates to \(\frac{\pi}{2a}\frac{a^{1/\alpha}}{\sin(\pi/a)}\left(1-\cos(\pi/\alpha)\right)\) for \(a > 0\) and \(-1 < \frac{1}{\alpha} < 1\). The discussion highlights the presence of first-order singular points at \(x = a\) and \(x = -a\), necessitating careful treatment of branch cuts, particularly along the negative imaginary axis. The Cauchy residue theorem is applied to evaluate the integral, revealing that only the residues at the poles contribute to the result. The need for proper handling of improper integrals and principal value integration is emphasized.
  • Complex analysis, specifically residue theory
  • Understanding of branch cuts in multi-valued functions
  • Knowledge of improper integrals and principal value integration
  • Familiarity with Mathematica for numerical integration
  • Study the application of the Cauchy residue theorem in complex integrals
  • Learn about branch cuts and their implications in complex analysis
  • Explore principal value integration techniques
  • Practice numerical integration in Mathematica, focusing on improper integrals
Mathematicians, physics students, and anyone involved in complex analysis or evaluating integrals with singularities.
elgen
Prove that
[itex]\int_0^{\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx = \frac{\pi}{2a}\frac{a^{1/\alpha}}{\sin(\pi/a)}\left(1-\cos(\pi/\alpha)\right)[/itex] where [itex]a>0[/itex] and [itex]-1<1/\alpha<1[/itex]
It is apparent that there are two first order singular points at x=a and x=-a. Since [itex]a^{1/\alpha}[/itex] is a multi-valued function, i select the branch cut to start at z=0 and extend along the negative imaginary axis.
The contour is the semi-circle in the upper half plane. Applying the Cauchy residue theorem, I conclude that only the arc integrations around the two simple poles contribute to the improper integral. I arrive at
[itex] \int_{-\infty}^{+\infty}\frac{x^{1/\alpha}}{x^2-a^2} dx =-\frac{1}{2} 2\pi i <br /> \left[ <br /> Res(\frac{x^{1/\alpha}}{x^2-a^2},x=-a) <br /> + <br /> Res(\frac{x^{1/\alpha}}{x^2-a^2},x=a) <br /> \right]<br /> = -\frac{1}{2}2\pi i <br /> \left[ <br /> -\frac{1}{2a} a^{1/\alpha} e^{j\pi/\alpha}<br /> +<br /> \frac{1}{2a}a^{1/\alpha}<br /> \right][/itex]
The result on the RHS of the above expression is not a real number.
Any comment on the possible source of error is appreciated.
elgen
There are some issues with that integral. For starters, just get it working for a simple case:
[tex]\int_0^{\infty} \frac{z^{1/2}}{z^2-4}dz[/tex]
And it has simple poles on both the negative and positive real axis so the integral won't converge in the normal sense but will converge in the principal sense so we should write:
[tex]P.V. \int_0^{\infty} \frac{z^{1/2}}{z^2-4}dz[/tex]
Now, we can still integrate along the negative real axis but will have to indent around the pole at z=-2. Also, in these cases, it's a good idea to get the numeric answer first then check your results to it. So in Mathematica:
Code:
In[7]:=
NIntegrate[Sqrt[x]/(x^2 - 4), {x, 0, 2, Infinity},
  Method -> "PrincipalValue"]
Out[7]=
1.1107207345395953
Ok then, does it even agree with that expression you gave above?. Can you set up the integrals to compute it symbolically now?
Edit: Just noticed maybe that's what you were implying above. What do those integrals look like then?
Thank you for the pointer. I found out that I did not express the improper integral correctly.
I took
[itex]\int_{-\infty}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx = 2 \int_{0}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx[/itex]
which is not correct. The correct way is that
[itex]\int_{-\infty}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx =<br /> \int_{-\infty}^{0} \frac{x^{1/\alpha}}{x^2-a^2} dx +<br /> \int_{0}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx<br /> =<br /> \lim_{R\to\infty}\int_0^R \frac{r^{1/\alpha} e^{j\theta/\alpha}}{r^2 e^{j2\theta}-a^2} dr|_{\theta=\pi}<br /> +<br /> \int_{0}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx<br /> = (1+e^{j\pi/\alpha})\int_{0}^{+\infty} \frac{x^{1/\alpha}}{x^2-a^2} dx[/itex]
Then everything falls off naturally.
  • · Replies 105 ·
13K
