Calculate Frenet Frame for \vec{r}(t)
  • Thread starter Thread starter BitterX
    Frame
The discussion focuses on calculating the Frenet frame for the vector \(\vec{r}(t)=(2t \cos t, 2t \sin t, 5t)\) and determining the acceleration in the Frenet frame. Two methods are highlighted: the first involves arclength parametrization to achieve unit speed, while the second utilizes formulas for the Frenet frame that do not require unit speed. The user expresses uncertainty about the arclength parametrization but ultimately finds the necessary information through independent research.
  • Understanding of vector calculus and parametric equations
  • Familiarity with the Frenet-Serret formulas
  • Knowledge of arclength parametrization techniques
  • Basic proficiency in calculus, particularly derivatives and integrals
  • Study the Frenet-Serret formulas in detail
  • Learn about arclength parametrization and its applications
  • Explore advanced vector calculus topics, including curvature and torsion
  • Review textbooks on differential geometry for comprehensive understanding
Students in advanced calculus or differential geometry courses, mathematicians, and anyone interested in understanding the Frenet frame and its applications in physics and engineering.
BitterX
calculate the frenet frame for the vector:
[itex]\vec{r}(t)=(2t cost,2tsint,5t)[/itex]
calculate the acceleration in frenet frame.
[itex]\hat{T}=\frac{dr}{ds}=\frac{\dot{r}}{|\dot{r}|}[/itex]
[itex]\hat{N}=\frac{\frac{dT}{ds}}{|\frac{dT}{ds}|}[/itex]
[itex]\hat{B}=\hat{T}\times \hat{N}[/itex]
I'm not too sure how to get to [itex]\vec{r}(s)[/itex]
what I tried is : [itex]s=2t \ \ \Rightarrow \vec{r}(s)= s(\cos \frac{s}{2},\sin \frac{s}{2},2.5)[/itex]
[itex]T=\frac{dr}{ds}=s(-\sin \frac{s}{2},\cos \frac{s}{2},0)+(\cos \frac{s}{2},\sin \frac{s}{2},2.5)[/itex]
which is NOT a unit vector.
if I try use t as the variable it's just becomes a gigantic answer.
There are two ways to solve this problem:
  • The first way is to put r into arclength parametrization. You should have seen several formulas in your course that show how to make r into a curve with unit speed. These formulas use integrals, so are not always handy or solvable, however.
  • The second way is to use formulas for the Frenet frame which do not require the curve to have unit speed. These formulas are a bit more complicated than the usual formulas.
So, look in your course for these things and see if you can do something with it.
Thanks.
I know the second way,and I did it like that.
About the first way, can you recommend on a book that show how to do it?
in our course it was only when z=0...
edit: nvm googled it...
I feel ashamed. Thanks!
