Time ordered product & Green's function
The discussion focuses on the application of the Klein-Gordon operator to the time-ordered product of scalar fields, specifically T(∅(x)∅(y)). The key equation derived is (\Box+m^2)T(∅(x)∅(y))=-δ^4(x-y), demonstrating the relationship between the time-ordered product and Green's function without directly referencing Green's function. The solution employs equal time commutation relations and the properties of the theta function, leading to a definitive conclusion about the behavior of the time-ordered product under the Klein-Gordon operator.
  • Understanding of Klein-Gordon operator and its applications
  • Familiarity with time-ordered products in quantum field theory
  • Knowledge of equal time commutation relations
  • Basic grasp of delta functions and theta functions
  • Study the derivation of Green's functions in quantum field theory
  • Learn about the implications of equal time commutation relations
  • Explore the properties of the Klein-Gordon equation in detail
  • Investigate advanced topics in time-ordered products and their applications
Quantum field theorists, physicists studying particle interactions, and advanced students seeking to deepen their understanding of time-ordered products and the Klein-Gordon operator.
johnahn
The problem is showing
(□+m^2)<0| T(∅(x)∅(y)) |0> = -δ^4 (x-y)
I know that it is relavent to Green's function, but the problem is that it should be alternatively solved without any information of Green's function, and using equal time commutation relations.
Does Anyone know that?
The point is to use the Klein Gordon operator on the T-product. Note that it is defined as [itex]T(\phi(x)\phi(y))=\theta(x^0-y^0)\phi(x)\phi(y)+\theta(y^0-x^0)\phi(y)\phi(x)[/itex] which means that when you apply the spatial derivation it passes through the thetas and acts directly on the fields. The time derivative needs a little more attention. You can perform an explicit calculation:
$$\begin{align}
\partial_0 T(\phi(x)\phi(y)) &= \theta(x^0-y^0)\dot{\phi}(x)\phi(y)+\delta(x^0-y^0)\phi(x)\phi(y)+\theta(y^0-x^0)\phi(y)\dot{\phi}(x)-\delta(x^0-y^0)\phi(y)\phi(x)\\
&=\theta(x^0-y^0)\dot{\phi}(x)\phi(y)+\theta(y^0-x^0)\phi(y)\dot{\phi}(x)
\end{align}$$
where I have used the commutation relation at equal time and the fact that the delta is the derivative of the theta.
To have the KG operator you have to perform another time derivative and thus obtain, with the same procedure:
$$\partial_0^2 T(\phi(x)\phi(y))=T(\ddot{\phi}(x)\phi(y))+\delta(x^0-y^0)[\dot{\phi}(x),\phi(y)]=T(\ddot{\phi}(x)\phi(y))-\delta^4(x-y)$$
where I have used again the commutation realtion at equal time (because of the delta).
Now, every other term in KG operator pass through the thetas and so you have:
$$(\Box+m^2)T(\phi(x)\phi(y))=T((\Box+m^2)\phi(x) \phi(y))-\delta^4(x-y)=-\delta^4(x-y)$$
because [itex]\phi[/itex] is solution of the KG equation.
I hope this was the answer you were looking for.
Einj
Thanks a lot Einj !
  • · Replies 18 ·
