Estimate nuclear energy generation rate (formula given) per unit MASS MASS?
The discussion centers on estimating the nuclear energy generation rate for the proton-proton (pp) cycle in the Sun, using the formula Epp = (0.241) (rho) (X^2) (T6 ^ (-2/3)) exp (-33.8/(T6 ^ 1/3)). The user correctly substituted the values for density (1.1 x 10^5 kg m^-3), hydrogen mass fraction (0.34), and temperature (T6 = 13) into the equation, resulting in an energy generation rate of 3.186 x 10^-4 W kg^-1. The user expressed confusion regarding the phrase "per unit mass mass," which appears to be a typographical error, as the unit W kg^-1 is appropriate for the context.
  • Understanding of nuclear fusion processes, specifically the proton-proton cycle.
  • Familiarity with thermodynamic concepts, particularly temperature scaling (T6).
  • Basic knowledge of density and mass fraction calculations in astrophysics.
  • Proficiency in applying mathematical formulas to physical scenarios.
  • Research the implications of varying density and temperature on nuclear fusion rates in stellar cores.
  • Study the role of hydrogen mass fraction in energy generation during stellar fusion processes.
  • Learn about the different fusion cycles in stars, including the CNO cycle and their energy outputs.
  • Explore advanced astrophysical modeling tools for simulating stellar energy generation.
Astronomy students, astrophysicists, and anyone interested in stellar physics and nuclear fusion processes in stars.
daleklama
Consider energy generation in the Sun. Fusion through the pp cycle takes place within its core which has
r = 0.2 Rs
T = 1.3 x 10 ^ 7 K
rho (density) = 1.1 x 10 ^ 5 kg m^-3
X (total mass fraction of hydrogen) = 0.34
The nuclear energy generation rate for the pp cycle (where T6 = T/10^6K and density has units of kg m ^ -3) is
Epp = (0.241) (rho) (X^2) (T6 ^ (-2/3) ) exp (-33.8/(T6 ^ 1/3)) W kg ^ -1
Estimate epp per unit mass mass.
I subbed everything in:
Epp = (0.241) (1.1 x 10 ^ 5) (0.1156) ( 13 ^ -2/3) exp (-33.8/ (13 ^ 1/3))
(T6 is 13, because it says in the question that T6 = T/10^6K)
and I got 3.186 x 10 ^ -4 as my final answer, I assume the unit is W kg ^ -1 because it was given in the formula.
The bit I'm confused by is that in the question it specifies "estimate epp PER UNIT MASS MASS."
That bit I haven't a clue about... did I do it wrong?
Thanks for any help!
W/kg is fine if the problem statement is "per unit mass" (or "per unit mass mass" which looks like a typo).
10K
9K
