How Do I Analyze and Graph the Function \( \frac{x}{x^2-4} \)?
The discussion revolves around analyzing and graphing the function \( \frac{x}{x^2-4} \). Participants are exploring various aspects of the function, including its domain, intercepts, asymptotes, and derivatives, while seeking to understand its behavior in terms of increasing/decreasing intervals and concavity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the function's domain and critical points derived from its first and second derivatives. There are questions about the implications of complex numbers when solving for critical points, and some participants suggest that the derivative method may not be effective due to the presence of asymptotes.
Some guidance has been offered regarding the behavior of the function, particularly concerning its decreasing nature and the existence of inflection points. Multiple interpretations of the function's characteristics are being explored, with participants sharing their derived information and seeking verification.
Participants mention the requirement to derive information without using graphing calculators, emphasizing the need to show all steps in their homework. There is a focus on understanding the implications of asymptotes and the behavior of derivatives in relation to the function's graph.
jzq
Sketch the graph of the function, using the curve-sketching guide.
Function: [tex]\frac {x}{x^2-4}[/tex]
So far I have derived this information from the function: (Please check!)
Domain: [tex](-\infty,-2)\cup(-2,2)\cup(2,\infty)[/tex]
y-int: (0,0)
x-int: (0,0)
Asymptote: x=-2 , x=2
First Derivative: [tex]f'(x)=\frac {-x^2-4}{(x^2-4)^2}[/tex]
Second Derivative: [tex]f''(x)=\frac {2x(x^2+12)}{(x^2-4)^3}[/tex]
The information that I need now is where it is increasing and decreasing; the relative minimum; where it concaves up and down; and the points of inflection. My problem is, when I plug in zero for y in the derivatives, it gets complicated. For example, the first derivative: (Please check!)
[tex]\frac {-x^2-4}{(x^2-4)^2}=0[/tex]
[tex]-x^2-4=0[/tex]
[tex]-x^2=4[/tex]
[tex]x^2=-4[/tex]
[tex]x=\sqrt{-4}[/tex]
Correct me if I'm wrong, if you square root a negative number, wouldn't you have to use imaginary numbers [tex](\imath)[/tex]? Any help will be greatly appreciated!
The derivative method will not necessarily work when the function has asymptotes like this one. Find the asymptotes and then find the concavity for each area. Plot it out by find if it does not make sense.
Here is online graphing java applet to help out.
http://www.math.unl.edu/~jorr/java/html/Grapher.html
You should stay in the real world, no complex numbers are needed. See [itex]f ' (x)[/itex]. It is always negative, it cannot be zero or positive. So your function is decreasing everywhere. It has neither local maxima nor minima.
[itex]f '' (x)[/itex] is zero at x=0, and there are domains where it is either positive or negative, so the function has got an inflexion point and domains where it is concave up or down.
ehild
Here is (or at least should be) your graph...
Daniel.
The way we're learning it, we're suppose to draw the graph w/o copying from a graphing calculator using the information derived from the function. After we found the derivatives, we have to set it = to 0, then find the critical numbers. With the critical numbers, we're then suppose to test it on a number line to find where it is positive or negative. From the first derivative number line, we find the decreasing and increasing intervals and the relative extrema. From the second derivative number line, we find the intervals where it concaves up and down and the points of inflection. I'm sure you all know this already. So basically, on my homework, I have to show how I got all my information. Thanks for your help!
  • · Replies 21 ·
