Centrifugal forces + pressure and CG
The discussion revolves around the dynamics of a rotating half torus composed of solid and liquid materials, focusing on the forces exerted by these materials during rotation. Participants explore concepts related to pressure, center of gravity (CG), and the behavior of solids and liquids under rotational motion. The scope includes theoretical considerations and modeling challenges in fluid and solid mechanics.
  • Some participants question whether water exerts pressure and if solid materials contribute to pressure in the same way as liquids.
  • There is a discussion about the role of a container in holding the liquid and how it applies forces to the liquid, which may affect the overall analysis.
  • One participant suggests that if the solid is imagined as being made of small parts connected by ropes, the pressure could be significantly reduced.
  • Another participant emphasizes the complexity of the problem, noting that both solid and liquid will experience non-homogeneous deformations and that the liquid will exhibit viscous flow.
  • There are considerations about whether the forces from the liquid and solid can be treated as negligible under certain conditions, such as when the angular velocity is constant.
  • Participants discuss the implications of changing angular velocity and how it complicates the analysis of forces within the system.
  • One participant proposes starting with simpler problems to build understanding before tackling the more complex torus scenario.
  • There is a mention of boundary conditions being crucial for determining stress distributions in the rotating system.
  • A question is raised about the applicability of these forces to the Earth's core, indicating an interest in broader implications of the discussion.
Participants express differing views on the nature of forces exerted by solids and liquids, the role of pressure, and the effects of rotational dynamics. There is no consensus on the specific mechanics involved, and the discussion remains unresolved with multiple competing perspectives.
Participants highlight the importance of boundary conditions and the complexities introduced by varying angular velocities. The discussion includes assumptions about the behavior of materials under rotation, which may not be universally agreed upon.
This discussion may be of interest to those studying fluid mechanics, solid mechanics, or rotational dynamics, as well as individuals exploring theoretical models in physics and engineering.
Gh778
Take half torus with solid part of density 1, other half torus with liquid of density 1. The torus turn at W rd/s enough for maintain liquid at external circle. Now, for 0 to 180° we accelerate torus, this increase forces (blue in drawing) from pressure of water and from 180° to 360° we deccelerate torus. Rotationnal speed change from W to W+w to W. It's like torus change the CG without external forces. I thought solid give pressure too but I can imagine 2 liquids with different density, it's the same. I have some questions:
1/ water don't give pressure so no force exist ?
2/ solid give same pressure ?
3/ when we rotate the forces from rotation, this cancel pressure forces ?
Edit: I add another drawing for show different positions
Maybe my questions are not precise enough ?
When I drawn solid in black, it's possible to imagine it maintain from center of circle with solid like this no pressure can appear from solid (imagine a lot of smal ropes for maintain all part of solid). So if solid don't give pressure, it is liquid that don't give pressure ?
Does this attachment help?
There is certainly a tangential ring pressure developed in a rotating ring. In a solid it is a stress and in a liquid it is pressure. Of course these are equal in your ring because the densities are equal. For unequal densities you would have to relocate the centre of mass.
I don't understand exactly what you are doing here, but one difference between the solid and liquid parts is that there must be a container that holds the liquid, and the container will apply a force to the liquid. If you ignore that fact, you will get the wrong forces and stresses.
I'll try to understand this evening. That I can't understand: if I imagine solid half torus like small parts, if each part is attached by a rope, the pressure could be limited a lot I think ?
ok, but this force (the force the container apply) will put on support that take system ?
This is actually a very complicated problem. Based on lots of experience in fluid and solid mechanics modelling, I can tell you that the best way to approach a problem like this is to start with some much simpler versions of the problem, and solve them first, and gradually add complexity until you get to the actual problem you are trying to solve. Why? First of all, if you can't solve the simpler versions of the problem, you certainly won't be able to solve the more complex problem. Secondly, you will gain understanding along the way from the solutions to the simpler problems.
In the system you describe, neither the solid nor the liquid will behave as a rigid body. Both will experience transient non-homogeneous deformations. The liquid will exhibit viscous flow that has to be accounted for, and the solid will exhibit elastic deformation that has to be accounted for. I suggest starting out with the following very simple problem:
Consider an infinitely long straight pipe containing a viscous fluid. Initially the pipe and the fluid are at rest. At time zero, the pipe is set in motion with a steady velocity V along its axis. What is the velocity and pressure distribution within the fluid as a function of time and radial position? If you can't solve this problem, you will never be able to do the torus problem.
As a second version of the problem, consider the same pipe and fluid, but this time make the imposed pipe velocity a function of time.
As a third problem, consider the case where there are rigid plugs within the pipe, and a finite length of fluid between the plugs. The plugs move with the pipe velocity.
With W = constant, it's a complicated problem too ? or it's because W change in time ?
With W=constant, are there forces from liquid ? I think forces from solid can't be near 0 if there is a lot of parts (imagine infinite number of parts and ropes). Even if there are forces from liquid is strange because even on a round forces cancel themselves if we place this system on another object in a part of time (60° for example), this change the CG of object I think.
For change velocity, we can change the rotation of the system or place a lot of stems for help solid and liquid to gain velocity very quickly. In theory, if velocity is apply on each atom of liquid and solid, forces are centripetal forces only.
Compresibiitiy or elasticity doesn't have any effect on the stress field, unless you want to model this as a large displacement nonlinear problem. The body forces that cause the centripetal acceleration are known from the geometry and density, and the body forces are also the gradient of the stress tensor. The stresses are independent of the material properties, for a given set of the boundary conditions.
The boundary conditions are the key to the actual stress distrubition. For a rotating solid thin ring or cylinder with no radial constraints imposed, the main stress compoent is tension around the circumference of the ring. But a fluid can't sustain any significant tensile stress (or negative hydrostatic pressure if you prefer to call it that), so there must be some radial constraint forces (for example the fluid pressure on the solid structure that is containing it) to make the situation physically realistic.
If the angular velocity is constant, then, as you indicate, then liquid and the solid can be treated as rigid, and the system will be statically determinate. However, if the angular velocity varies with time, then you have to consider the deformational mechanics of both the solid and the liquid.
If W is constant, then, as AlephZero points out, the analysis is much simpler than if W varies with time. But this is not the problem that you posed.
Could any of these forces apply to the Earth's core?
1/ I would like to know if there are forces from pressure of liquid when W = constant ? AlephZero said that container would give the same force but that force come from the support of the system, right ? So the system oscillate around a point, the CG move ?
2/ If W varies with time, it's easy to change the system for accelerate/deccelerate not the support of the system but a lot of parts of solid and liquid for reduce problem from deformation I think.
@Studiot:
Where come from this tangential force ? Could you explain, I don't understand ?
@Blind light:
Do you know an effect not explain on Earth and forces can explain ?
...but that force come from the support of the system, right?
I don't think AZ mentioned the system support, however you did in post#5.
AZ did say
and I concur exactly.
So let us take things one step at a time.
Do you understand the idea that any rotating object will be subject to internal forces that can be resolved in two directions at right angles - radially and tangentially?
No, I don't understand that. I see only centripetal forces. Could you explain ?
you don't understant the system or the goal of the system ? If it's the goal, it's only for study it. I know the CG can't move but I don't see that.
Which direction do you think angular momentum acts?
(I want to understand first when W = constant) it's tangential but I don't see how forces come from on your drawing at message #3
Maybe for me it's easier to understand with small solid deformable material. I imagine a part of sector like drawing show. The material is solid but deformable. The deformation put pressure at right and at left, where is the C force in your message #3 ? The deformation is more and more high at external circle.
Your last sketch is not far off, so we are getting somewhere. I have drawn something similar in fig4 of the new attachment.
Starting with the static situation of a ring or section of a cylinder under internal pressure, Fig1 shows the internal pressure tending to burst apart the ring. This would break it across some diameter, say AA.
The bursting pressures and forces act radially.
Fig2 shows how this bursting is resisted. There must be a forces F-F acting across the section AA, holding the ring together.
These forces exactly equal the bursting forces and are equivalent to the forces F in my earlier diagram in post#3
Fig 3 shows how the forces F-F must be the same all the way round the ring to preserve equilibrium.
The resisting forces are therefore tangential or circumferential.
They are called hoop stresses or forces, after the iron hoops used to hold wooden barrels together.
Now in Fig4 we proceed to a rotating situation. Here the internal pressure is replaced by the a stress due to the increasing radius in the inner and outer faces of a small segment. This is like your last sketch.
The circumferential stresses are considered constant and equal to the hoop stresses described before.
(Note I have moved from forces to stresses the force is obviously stress time cross sectional area.)
Now a rotating disk is not in equilibrium.
However we may use equilibrium analysis if we introduce the fictitious centrifugal force to balance the real centripetal one. This is equal and opposite to the centripetal force and the technique is known as D'Alembert's Principle.
Alternatively we may analyse the motion by Newton's laws of motion using the centripetal acceleration.
I have done this in the previous attachment and called the centrifugal force C.
This equals mass times distance to the centre of mass of the rotating half ring times the square of the angular velocity.
Using D'Alembert allows me to then use the laws of equilibrium to equate this to the two hoop forces acting across the cut line forming the diameter of the half ring.
Ok, like that I understand :)
If I change liquid and take gas, gas can pressure liquid at 2 surfaces of half torus but gas can't pressure itself because temperature prevent this, how does it works in this case ?
Swirling gasses are still subject to rotational forces, but please keep to the step by step approach as I am having trouble understanding where you are heading.
I envisage your original question to apply to something like say a petri dish, containing a liquid and with some plasticine or bluetack sausage pressed round the inside of half the rim. If you centred the dish on a turntable and rotated it this would form the half solid half liquid ring you talk about and the forces would be as we have discussed.
In principle the same would apply to a gas, however the speeds required to move the gas aswy form the centre and collect towards the rim would be enormous. You should always expect a significant density distribution radially.
Yes, I speak always with my dish with solid/liquid or solid/gas.
And now, if speed varies, the problem come from the speed of sound in liquid or gas ?
What problem? You didn't specify.
Of course, with a gas, you may be moving away from a petri dish and Aleph Zero's confining structures may be forces (magnetic, electric, gravitational).
You haven't mentioned the scale of your thoughts either. Spiral galaxies are formed by processes like these.
The scale is 1 m or 10 meters only, a human mechanical system.
The problem I don't understand is when the system accelerate, the delay for transmit energy is not zero, it depends of the sound in material. I think it's that Chestermiller would like to say in its messages. See drawing
Sorry I don't understand.
The system is always accelerating if it is rotating, even if the angular velocity ω is constant. If ω is constant then the acceleration is constant.
What energy are you trying to transmit and what does this have to do with the rotation?
I increase W, the gas form a shape, if I take the same shape for solid (see last drawing), I see a force that move cog, what compensate this ?
I have no idea what you mean by this.
1/ I come back to the torus when W is constant. Full torus with liquid. Now if we increase the radius of the system, we need kinetics energy for additional liquid sure and increase radius (add water). But the C force is like an additionnal force that increase energy of the system. If the radius increase, we can put water in the center, we need energy for rotate water, ok, but water move outside circle more easily due to the C force.
If I compare the potential energy in a rotational solid and a fluid it's not the same ?
2/ Centrifugal forces apply a pressure like gravity can do. The pressure is more at external with C, it's easier to move an empty object at external circle ? See drawing.
With the shape I drawing, solid and liquid has the same density, I don't know how forces from pressure (F+C) can cancel themselves ?
What makes you think the forces cancel?
It would help if you drew the correct forces.
When analysing a mechanical problem you need to distinguish between applied or external forces (also called loads) and internal forces which appear as stresses.
The response of a liquid is different from the response of a solid to external force.
However the external applied force will be the same in both from the same source.
Please not that Chestermiller has already said this is a very complicated problem (post#6).
In my post 19 I posted a partial differential equation that takes three pages of maths to solve, even after simplifyung to an ordinary differential equation. Are you up for this?
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 30 ·
