What are the units of a definite integral and its derivative?
The discussion clarifies that the units of a definite integral and its derivative are determined by the units of the functions involved. For the integral of a function f(x), the units are the product of the units of x and y, resulting in square units when considering area under the curve. For example, integrating f(x) = x³ from 1 to 3 yields 20, which has square units if both x and y are in meters. Conversely, the derivative dy/dx has units derived from dividing the units of y by the units of x, such as meters per second for velocity.
  • Understanding of definite integrals and their geometric interpretation
  • Familiarity with derivatives and their physical significance
  • Knowledge of units of measurement in physics and mathematics
  • Basic calculus concepts, including Riemann sums
  • Study the relationship between units in calculus, focusing on integrals and derivatives
  • Explore the concept of Riemann sums in detail
  • Learn about dimensional analysis in physics and its applications
  • Investigate specific examples of integrals and derivatives in real-world scenarios
Students of calculus, educators teaching integration and differentiation, and professionals in fields requiring mathematical modeling and analysis.
AbsoluteZer0
Hi,
Suppose we have f(x) = x3.
Integrating this function using the definite integral with the upper boundary being 3 and the lower boundary being 1 would result in 20. Does 20 have any units or is it unitless? Seeing how it is the area underneath a curve, I would imagine that it has square units. If you were to differentiate this function you would get [itex]\frac{dy}{dx}[/itex]=3x2. Does the derivative have any units?
Thanks,
Say y=f(x).
When you integrate the units are the product of the units of x times the units of y.
If you differentiate dy/dx the units are the units of y divided by the units of x.
Ex: If y has length units (m) and x has time units (s), then the integral will have units m*s and the derivative will have units m/s.
If y=x^3, then your units for y might be the units of x cubed, but it depends on the problem. If y = volume of a cube with sidelength x, then units of y are units of x cubed.
Recall that a integral is a limit of a sum,the Riemann sum, [itex]\sum f(x_i)\Delta x[/itex] so its units are that of a product of whatever units f(x) has and whatever units x has. That is why we typically introduce integrals in terms of "area under the curve"- if x has units of, say meters, and y= f(x) has units of meters also, then the integral [itex]\int f(x)dx[/itex] has units of "meters squared" or "square meters", an area measure.
On the other hand, if v(t) is a velocity, so that v has units of "meters per second" and t has units of "seconds" then the integral has units of "meters per second" times "seconds" or "meters": [itex]\int v(x)dx[/itex] will give the distance the object has moved.
The derivative is the other way around. It is a limit of [itex]\Delta y/\Delta x[/itex] so it has units of what ever the units y has divided by the units of x. If f(t) is the distance, in meters, an object moves in t seconds, then df/dt has units of "meters per second", a speed.
  • · Replies 20 ·
  • · Replies 27 ·
  • · Replies 23 ·
