| New Reply |
does standing on bathroom scale depress or compress spring |
Share Thread |
| Nov13-12, 05:51 PM | #1 |
I am unsure how bathroom scales work. Does your weight compress or depress the spring? Do scales measure the upward or downward force? Please explain in detail.
| Nov13-12, 05:59 PM | #2 |
Mentor
| Nov13-12, 06:36 PM | #3 |
Thanks for your reply. I am still confused as to whether when you stand on a scale you are pushing the spring down, which sounds more likely or whether as is written in some books, the spring is pushing up. Also is your weight measured from the scale pushing up, or from your weight pushing down. I appreciate the clarification so I can really understand how the scale works.
| Nov13-12, 06:43 PM | #4 |
Mentor
does standing on bathroom scale depress or compress springF = -kΔx That means that the force F down on the spring will cause its size to shrink in proportion to the force (and in relation to the "spring constant" k). So if object 2 is twice as heavy as object 1, object 2 will cause twice as big of a Δx shrinkage. The movement down of the scale platform is used to turn the indicator to the corresponding weight of the object. The farther down the spring is compressed, the more the dial moves to show the heavier weight. More info on springs: http://en.wikipedia.org/wiki/Spring_(device) . |
| Nov13-12, 06:46 PM | #5 |
Mentor
All forces come in similar pairs. |
| Nov13-12, 06:57 PM | #6 |
Plus, it could be instructive to explore the use of strain-gauges in decent scales. Springs are not the end-all.
| Nov13-12, 07:55 PM | #7 |
Thanks everyone,
one last question which I still do not have clarified is whether the scale is measuring the restoring force or the actual force of the weight. |
| Nov13-12, 08:43 PM | #8 |
Mentor
| Nov13-12, 08:56 PM | #9 |
You have all really clarified this for me. Thanks for your time.
| New Reply |
Similar discussions for: does standing on bathroom scale depress or compress spring
| A student stands on a bathroom scale in an elevator at rest on the 64th floor of ... | Introductory Physics Homework | 7 | ||
| Magnetic Field To Compress A Spring | General Physics | 7 | ||
| Work to Compress Spring | Introductory Physics Homework | 3 | ||
| Bathroom scale being compressed but jumping on it | Introductory Physics Homework | 13 | ||
| bathroom scale | Introductory Physics Homework | 7 | ||
