Are Equivalent Wave Functions Physically Equivalent in Quantum Mechanics?
The discussion revolves around the physical equivalence of wave functions in quantum mechanics, particularly focusing on the implications of defining equivalence relations for position and momentum wave functions. Participants explore theoretical aspects, mathematical formulations, and the impact of affine structures in quantum mechanics.
  • One participant questions the validity of treating position and momentum wave functions as vectors in a vector space, suggesting that doing so introduces non-physical data through the choice of origins and inertial frames.
  • Another participant asserts that the concept discussed relates to the projective Hilbert space of quantum systems, where pure quantum states are equivalence classes of vectors, but acknowledges that the proposed equivalence relation differs from standard definitions.
  • A later reply challenges the strength of the proposed equivalence relation, arguing that it does not preserve vector space structure and may separate wave functions that should be considered equivalent.
  • One participant expresses uncertainty about how to reconcile quantum mechanics with changes in spatial origin or inertial frames, indicating a lack of consensus on this issue.
  • Another participant introduces the idea that the affine structure in quantum mechanics is represented through unitary transformations related to translation symmetries, but seeks clarification on the implications of this in the context of the discussion.
  • There is a request for references regarding theorems by Wigner and Bargmann, indicating a desire for deeper understanding of the theoretical background.
  • Participants express confusion about the formalism and its ability to represent different wave functions as valid representations of the same physical object.
Participants do not reach a consensus on the equivalence of wave functions or the implications of affine structures in quantum mechanics. Multiple competing views and uncertainties remain regarding the definitions and relationships of wave functions.
Participants highlight limitations in their understanding of how quantum mechanics accommodates changes in spatial origins and inertial frames, as well as the implications of their proposed equivalence relations on the vector space structure.
burakumin
Hello
I have a problem in understanding wave functions
Let [itex]q \mapsto \phi(q)[/itex] a position wave function for a single particle of mass [itex]m[/itex]
The equivalent momentum wave function is said to be computable with using Fourier transform:
[tex]\psi : p \mapsto \int_q \phi(q) \cdot e^{-i/\hbar \cdot \langle p, q\rangle} \delta^3 q[/tex]
with [itex]\langle , \rangle[/itex] the duality bracket or inner product (depending if you consider duality or not). But I feel unconfortable because technically (if you consider strictly galilean space-time) [itex]q[/itex] is not a vector but a point in an affine space. Turning it into a vector is equivalent to choosing a origin (= injecting non-physical data into my modelisation). Similarly the set of all possible [itex]p[/itex] for my particle is also a affine space. Turning it into a vector is equivalent to choosing a inertial frame (= which again corresponds to non-physical data in my modelisation).
By making explicit those two origins, I can compute:
[tex]\psi_0 : p \mapsto \int_q \phi(q) \cdot e^{-i/\hbar \cdot \langle p - p_0, q - q_0\rangle} \delta^3 q[/tex]
[tex]\psi_1 : p \mapsto \int_q \phi(q) \cdot e^{-i/\hbar \cdot \langle p - p_1, q - q_1\rangle} \delta^3 q[/tex]
And of course [itex]\psi_0 \neq \psi_1[/itex].
But by defining the equivalence relation :
[tex]\psi_A \sim \psi_B \Leftrightarrow \left( \exists p_*, \exists \vec p, \exists \vec q: \psi_A(p) = e^{-i/\hbar \cdot \langle p - p_*, \vec q\rangle} \cdot \psi_B(p + \vec p) \right)[/tex]
we have [itex]\psi_0 \sim \psi_1[/itex].
It seems that [itex]\sim[/itex]-equivalence on (position or momentum) wave functions is compatible with vector space structure and with Fourier transform (though I've not checked for the hermitian product).
So my question is: am I right to consider that two equivalent (position or momentum) wave functions are physically equivalent and that one should not consider the classical Hilbert spaces of position and momentum wave functions but rather their respective quotient spaces by relation [itex]\sim[/itex] ? If true, should I consider an even weaker equivalence relation ?
Thanks
Of course, all you've 'discovered' is the projective Hilbert space of a quantum system, i.e. the space of (unit) rays on a (complex, separable) Hilbert space, i.e. the space of all pure quantum states. A pure quantum state is thus an equivalence class of vectors.
Sorry dextercioby, but even if it's true that generally wavefunctions in the same ray are indeed considered equivalent (I already had this in mind but I wasn't considering this issue to begin with) it is obvious that the equivalence relation I introduced is different from the [itex]\mathbb{C}[/itex]-colinearity that one uses to create projective spaces.
Actually I was wrong on one point: my relation does not conserve the vector space structure and I feel that it is not a very good candidate. But even if we don't care about the vector space structure, the [itex]\mathbb{C}[/itex]-colinearity you're suggesting is still too strong. It separates different wavefunctions that should not be separated for the reason I've explained in my previous message: Fourier transform will match a single position wavelength to non-[itex]\mathbb{C}[/itex]-colinear momentun wavelength depending on how your choose a spatial origin and an inertial frame.
So this means nobody has a clue on how to make quantum mechanics consistent with change of spatial origin or change of inertial frame ?
Hmm, I'm thinking that the affine structure on the parameter space (R, R^2, R^3 for Quantum mechanics done on non-curved manifolds) is implemented in the formalism through the linear unitary (continuous in the norm topology) representations of the translation group, i.e. psi(x) and psi(x-x_0) as ordinary vectors of unit modulus from the respective rays are linked through a unitary operator, if the quantum system admits pure space translations along Ox axis as a symmetry (consequence of theorems by Wigner and Bargmann).
The Fourier transformation takes the ray of psi(x) into the ray of psi(p), inasmuch the ray of psi(p) is mapped into the ray of psi(p-p_0).
Right, I'm only considering stricty non-relativistic quantum mechanics on flat spacetime manifold. I don't know anything about Wigner and Bargmann theorems but the sole information I can find when I'm using those two names as keywords deals with relativistic wave equations. So what are you referring to ? Any reference ?
Sorry but this is not very clear. I still don't see where or why the formalism allow to think about the functions [itex]\psi_0[/itex] and [itex]\psi_1[/itex] defined in my first message as valid representations of the same object.
  • · Replies 24 ·
  • · Replies 61 ·
