New Reply
Eigenfunction of a Jones Vector (System)
Share Thread Thread Tools
Nov15-12, 02:35 PM   #1
I am trying to find out just how to solve for the eigenfunction given a system, namely the parameters of an optical system (say a polarizer) in the form of a 2 by 2 Jones Vector. I know how to derive the eigenvalue, using the the constituent det(λI -A) = 0, 'A' being the system at hand and 'λ' the eigenvalue. How do you go about solving for the eigenfunction?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov15-12, 03:14 PM   #2
Recognitions:
This is a pure math question. Try the following:
http://mathworld.wolfram.com/Eigenvalue.html
http://www.math.hmc.edu/calculus/tutorials/eigenstuff/
http://www.sosmath.com/matrix/eigen2/eigen2.html
Nov16-12, 05:15 PM   #3
Once you've found λ, you can substitute its value into Av = λv. If you then multiply out the left hand side and equate components, v1 and v2, of v on either side, you'll get two equivalent equations linking v1 and v2. Eiter will give you the ratio v1/v2. This is fine: the eigenvalue equation is consistent with any multiplied constant in the eigenvector. There will be a normalisation procedure for fixing the constant.
Nov16-12, 07:39 PM   #4
so I got λ = 1. 'A' I assume is the system matrix or my Jones Vector, which is given as a 2 by 2 matrix. So that makes Av=v, thus A must be 1?? The 'v' values must be the same, but isn't 'v' the eigenfunction itself? The equation Av=v eliminates the 'v' value. What am I doing wrong here?
Nov17-12, 02:39 AM   #5
v is the vector and A is the matrix. The matrix isn't a vector, but is an operator which operates on the vector.
Try it with a matrix A representing a linear polariser at 45° to the base vectors. This matrix has all four elements equal to 1/2. This gives eigenvalue of 1, and on substituting as I explained above, shows the two components, v1 and v2, of the vector to be equal, which is just what you'd expect.
New Reply
Thread Tools
Similar Threads for: Eigenfunction of a Jones Vector (System)
Thread Forum Replies
What does it mean that vector is independent of coordinate system Introductory Physics Homework 5
show that this system is not a vector space Calculus & Beyond Homework 3
Jones vector of circularly polarized light Classical Physics 1
Jones gives quantum algorithm for Jones knot polynomial Beyond the Standard Model 0
