| New Reply |
Conservation of Momentum Question |
Share Thread | Thread Tools |
| Nov15-12, 11:49 PM | #1 |
Hello,
Here is the situation I have been pondering: A person is sitting in a shopping cart at rest. By throwing their weight forward they are able to cause the shopping cart with them inside to move. My question is how this works. If momentum is conserved unless an external force acts on the system and the initial momentum is zero when the cart is at rest, how is the shopping cart with the person inside able to move forward? Thanks |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov16-12, 12:22 AM | #2 |
Recognitions:
If the cart is completely frictionless, it won't work. The center of mass will stay put.
In the real world, however, there is going to be friction. You can use static friction to allow you to pick up the speed without pushing the card back. Effectively, via friction of cart with ground, you are pushing from the ground. Once you pick up speed, you hit the wall of the cart. The impact generates brief, but very high force. That force easily overcomes static friction causing the cart to roll. Once in motion, friction is much lower, so you can travel some distance before coming to a stop. In terms of conservation of momentum, the momentum of you + cart is not conserved, but that's not a closed system due to friction. Momentum of you + cart + Earth is conserved. |
| Nov16-12, 12:25 AM | #3 |
Recognitions:
Welcome to PF;
Notice that the cart moves in the direction the person throws themselves? Throwing forward should make the cart go backwards shouldn't it? That should be a clue... there is friction involved. It is the sudden shift from going forward to stopping that overcomes the static friction, allowing the cart to move. The change in momentum in that short time is backwards, so the cart goes forwards. (You may not think of this as an "impact" ;) ) |
| Nov16-12, 07:32 AM | #4 |
Thank you Simon and K^2! Great answers from both of you.
| Nov17-12, 10:55 AM | #5 |
Because I thought if we were shooting the front of the cart it would go forward because the change in momentum is greater when the ball bounces off, even with no friction. Or I guess kicking might be different, Im probably way off. |
| Nov17-12, 01:10 PM | #6 |
If the paint ball lands inside the cart then momentum is conserved and you end up motionless. If the paint ball lands outside the cart then what you have is essentially a needlessly complex rocket motor. |
| Nov17-12, 01:35 PM | #7 |
I should mention that in a frictionless case, the cart would move backwards while you were running forward and then perhaps go forward a bit when you hit the front, leaving the COM at the same place. But because running forward provides a much smaller force, the cart does not overcome static friction until you hit the front of the car.
The possibility of moving the car forward while you're in the car is the same as the possibility of moving yourself forward while standing without anybody pushing you. |
| Nov17-12, 01:52 PM | #8 |
You sit in the cart and fire the arrow. Would the cart move backwards when you fire. Would the cart move forewards when the arrow reached the end of it's flight and jolted the string, the bow, the person, the cart. |
| Nov18-12, 12:55 AM | #9 |
Recognitions:
| Nov18-12, 01:15 AM | #10 |
Recognitions:
... when you reel in the arrow, slowly, the cart stays in place. Reel in the arrow quickly and you risk overcoming the static friction.
| Nov18-12, 04:32 AM | #11 |
Aside from the static friction that prevents rolling, there is also the lateral static friction that prevents wheels from sliding sideways. Since a shopping cart has caster wheels this also plays a role when someone is throwing his weight around in the cart. Even with wheels that have zero static rolling friction, you could potentially get the center of mass moving.
| Nov18-12, 10:38 AM | #12 |
| Nov19-12, 01:40 AM | #13 |
Recognitions:
It's the net difference due to the arrow's momentum that results in your total momentum after firing the arrow being directed backwards. So the cart will roll backwards as result of the recoil until the arrow is stopped by the rope tied to it. Edit: This would actually be a fun one to demonstrate like that. If the weather improves for a day or two, I'll try to film it. The momentum carried by the arrow is quite significant. Should be enough to get me rolling on a skate board. |
| Nov19-12, 10:42 AM | #14 |
My bet is the two recoils has more force than the one. |
| Nov19-12, 11:10 AM | #15 |
| Nov19-12, 11:41 AM | #16 |
Recognitions:
But I've got nothing against the experiment. So I'll set it up. I've figured out location, so now I just need to borrow a skate board from somebody. (Mine's a 2-wheel caster, so that won't work.) Now, what would be really great is if you could see the influence of all the individual recoil stages, but I doubt I'd be able to catch that on camera. The net result should be plainly visible, though. |
| Nov19-12, 06:21 PM | #17 |
becuse the change in momentum is greater when it bounces of the front of the cart . ok so now it is headed to the back of the cart and it bounce of their so that should appose the motion. Now its headed back to the front of the cart. it still seems like the cart will move forward on average. There is porbably some subtle things I am missing. |
| New Reply |
| Thread Tools | |
Similar Threads for: Conservation of Momentum Question
| Conservation of four momentum question | Special & General Relativity | 3 | ||
| Question about conservation of momentum | General Physics | 1 | ||
| 2D Conservation of Momentum Question | Introductory Physics Homework | 1 | ||
| Question about the conservation of momentum? | General Physics | 5 | ||
| Conservation of Momentum Question | Introductory Physics Homework | 5 | ||
