Fluid Mechanics and SHM question Question
The discussion revolves around a physics problem involving a cylindrical object with an outer diameter of 10 cm, height of 20 cm, and density of 8000 kg/m³, supported by a vertical spring with a spring constant of 500 N/m. The first part of the problem requires calculating the elongation of the spring when the object is in equilibrium, while the second part involves determining the time period of oscillations when the object is slightly depressed and released. The problem is sourced from "HC Verma Concepts of Physics part 1".
  • Understanding of buoyancy and Archimedes' principle
  • Knowledge of Hooke's Law and spring constants
  • Familiarity with simple harmonic motion (SHM) concepts
  • Ability to perform calculations involving density and volume
  • Calculate buoyant force acting on submerged objects
  • Learn about the derivation of the time period for simple harmonic motion
  • Explore the relationship between mass, spring constant, and oscillation frequency
  • Study examples of oscillations in fluid mechanics
Students studying physics, particularly those focusing on fluid mechanics and oscillatory motion, as well as educators looking for practical examples to illustrate these concepts.
Swaraj M
Can please anyone solve the following question in details...
A cylindrical object of outer diameter 10 cm height 20 cm and density 8000 kg/m3 is supported by a vertical spring and is half dipped in water. Spring constant is 500N/m.
(a) Find the elongation in the spring in equilibrium condition
(b)If the object is slightly depressed and released, find the time period of resulting oscillations of object.
Source: HC Verma Concepts of Physics part 1
Thanks for looking!
Hi Swaraj M! Welcome to pf! :smile:
As per the rules, you need to show us your attempt at the problem before asking for help.
