Any methods to connect 20W solar panel?
  • Thread starter Thread starter JesseConant
    Solar Solar panel
The discussion revolves around connecting a 20W solar panel to a services bank, focusing on the wiring configuration, fuse requirements, cable specifications, and the integration of a battery monitor. Participants seek advice on best practices for this setup, including the correct connections for positive and negative terminals.
  • Homework-related
  • JesseConant asks whether the negative connection should go to the right side of the shunt and whether the positive should connect to battery 2 or either of the domestic batteries.
  • JesseConant inquires about the necessity of a fuse for the positive connection, the appropriate amp rating for the fuse, and recommendations for cable size and type.
  • Some participants emphasize the importance of determining the solar panel's voltage and current output before making connections.
  • There are suggestions to calculate the fuse size based on the solar panel's current output to prevent electrical hazards.
  • One participant advises that the cable length should be kept short to minimize energy loss, but as long as the cable diameter is adequate, length may not significantly affect performance.
  • There is a request for JesseConant to provide a diagram to facilitate better assistance, as some participants cannot visualize the setup without it.
The discussion contains multiple competing views regarding the specifics of the connections and requirements for the solar panel setup. There is no consensus on the best approach, and participants express uncertainty about the details of the connections and configurations.
Participants have not provided definitive answers regarding the correct connections or specifications, and there are missing assumptions about the solar panel's characteristics and the specific battery bank setup.
JesseConant
Hi all,
I am planning to connect a 20W solar panel on my services bank (via a regulator). I have made a little diagram that hopefully will make things easier.
As you can see, I have two separate banks, using a common negative. In the services bank I have a NASA BM1 battery monitor connected. So, to connect now the solar panel, I am correct that the negative goes to the right side of the shunt (as per diagram)?
Also do I need to connect the positive to battery 2 or to either positive of the two domestic batteries? Do I need a fuse for the positive connection and if yes how much amp? What size (diameter) or type of cables do you recommend (the panel does not include anything)? As long as the diameter is fine, does it matter how long the cable to the solar panel is?
Thanks
Jesse
http://www.solarmodulesystem.com/userfiles/image/largepic/20120206170902_7527500.jpg
JesseConant said:
Hi all,
Thanks
Jesse
Hello JesseConant, and welcome to Physics Forums.
I'm sorry, but I can't answer any of your questions, because I cannot find your diagram.
Hi OmCheeto,
Thanks for your kind concern on my problem anyway, I am just awaiting if other experienced people who might help me connect << Commercial link removed by Moderators >>?
JesseConant said:
Hi OmCheeto,
Your commercial link looked like spam, so I removed it. Post/upload the diagram you mention, or this thread will be deleted.
I would recommend the following steps to connect a 20W solar panel to a services bank:
1. Determine the voltage and current output of the solar panel. This information should be provided by the manufacturer or can be measured using a multimeter.
2. Calculate the size of the fuse needed for the positive connection based on the current output of the solar panel. It is important to use a fuse to protect the panel and the battery from any potential electrical hazards.
3. Choose the appropriate size and type of cables based on the current output of the solar panel. The cables should be able to handle the current without overheating.
4. Connect the negative terminal of the solar panel to the right side of the shunt, as shown in the diagram. This will allow the battery monitor to accurately measure the current coming from the solar panel.
5. Connect the positive terminal of the solar panel to either positive terminal of the domestic batteries, or to battery 2 if it is a separate bank. This will allow the solar panel to charge the batteries.
6. Make sure all connections are secure and tight to prevent any loose connections that may cause electrical issues.
7. It is important to keep the cable length between the solar panel and the battery bank as short as possible to minimize energy loss. However, as long as the cable diameter is sufficient to handle the current, the length should not affect the performance of the solar panel.
8. Test the system to ensure that the solar panel is charging the batteries properly and the battery monitor is accurately measuring the current.
I would also recommend consulting with a professional or referencing the manufacturer's guidelines for additional guidance and safety precautions.
  • · Replies 31 ·
  • · Replies 32 ·
