New Reply
Plasma colour in a sputtering chamber
Share Thread Thread Tools
Nov21-12, 01:42 AM   #1
Hi everyone,
my question is: what information can someone get by just looking at the colour of a plasma?
I the elements inside the chambers, together with some(few) common impurities.
Using the common spontaneous emission formula i can guess what transition emitted light with a particular frequency, but i don't have any database to make that data meaningful...
thank you
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Iron-platinum alloys could be new-generation hard drives
Nov21-12, 06:15 AM   #2
Admin
Quote by teoporta View Post
Hi everyone,
thank you
Inductively-coupled plasma optical emission spectroscopy is a common method for analyzing elements in a material.
http://www.wfu.edu/chemistry/courses...icpreprint.pdf
One would need to calibrate one's system with a standard. One usually uses a standard obtained NIST.
There are other techniques for surface analysis:
http://www.chem.qmul.ac.uk/surfaces/scc/
Nov21-12, 11:36 AM   #3
Mentor
Actually, I'm not sure if you can make such analysis of the glow in a plasma used for sputtering.
In a reactive sputtering where the sputtered specie react with a gas that has been backfilled, you can tell the difference in the color between reactive and non-reactive, i.e. you detect a qualitative difference. However, whether you can make elemental analysis from the color, that I haven't seen done before.
Zz.
Nov21-12, 09:23 PM   #4
I see. Thank you for both your answers.
In my case it's normal magnetron sputtering.
Can a different amount of oxigen in the chamber change the colour of the plasma?
I'm sputtering using a Ti target:
If plasma is green it forms a Ti film, if it's light blue it forms TiO2 film...
New Reply
Thread Tools
Similar Threads for: Plasma colour in a sputtering chamber
Thread Forum Replies
Plasma Based Chamber General Engineering 3
In a magnetic confinement fusion reactor chamber, how does the gas turn into plasma? Classical Physics 3
precombustion chamber and compression chamber Mechanical Engineering 1
Argon sputtering onto Al(111) Advanced Physics Homework 0
What is plasma sputtering?? General Physics 8
