Calculation of magnetic force on a wire
The discussion revolves around the feasibility and calculation of the magnetic force required to move a steel wire against frictional forces using a magnet. Participants explore the theoretical and practical aspects of this problem, including the necessary parameters for calculation and experimental considerations.
  • Experimental/applied
  • Homework-related
  • Rupak inquires about the possibility of moving a steel wire using a magnet and asks for the approach to calculate the force acting on the wire.
  • Another participant confirms that it is possible to move the wire with a magnet and suggests that the calculation approach is similar to any force calculation, emphasizing the need to identify relevant forces.
  • One participant notes that while steel can be attracted by a magnet, computing the force is complex and not straightforward, as it depends on the wire's permeability and its effect on the magnetic field.
  • Another participant mentions that this type of problem is often presented in college electromagnetic courses, indicating that while the geometry may be simple, the calculations can be challenging.
  • Rupak expresses a desire to calculate the strength of the magnet needed for an experimental setup where the wire must be moved along a duct.
  • A participant suggests starting with an idea of the magnetic strengths available and asks for details about the wire and duct dimensions, as well as the material properties, to refine the calculations.
  • There is a mention of different types of steel responding differently to magnets, which could affect the calculations.
  • One participant estimates that a basic classroom bar magnet could move a small amount of steel wire through a few millimeters of PVC plastic, recommending the use of the largest magnet available.
Participants generally agree that it is possible to move a steel wire with a magnet, but there is no consensus on the specifics of calculating the force involved, as multiple views on the complexity and necessary parameters remain. The discussion reflects uncertainty regarding the exact approach to take.
Participants highlight the need for specific information about the wire and duct dimensions, as well as the material properties, which could influence the calculations. The complexity of the magnetic force computation is noted, particularly regarding the wire's permeability and its interaction with the magnetic field.
banerjeerupak
Hi,
I would like to know if it is possible to move a steel wire against frictional forces using a magnet. What would be the approach of calculating the force acting on that thin wire. I would know the dimensions of the wire and the dimensions of the magnet. What other values should I find from data table.
Thanks
Rupak
It is - you can easily see this with any handy magnet and a bit of wire since all normal situations involve friction to some extent.
Same as any force calculation - or you could measure it directly.
Which forces do you need to calculate?
Take a look at the equations and definitions of the forces and see.
You can definitely attract steel with a magnet, but the force is seriously complicated to compute. Don't hope for anything like B*I*L. It depends on how the wire's permeability deforms the field.
... but it is the sort of thing sometimes offered as a homework problem in college e-mag courses. The geometry is usually simple and permeabilities are provided. I agree it's usually a pain. We really need the context to be of real help.
What I am really trying to do is move a length of wire along a duct, from outside the duct. I will be doing it experimentally. However, it would help if I could calculate the strength of the magnet I would need rather than trying to guess and do it by trial and error.
Start with an idea of the range of choice for magnetic strengths that will be available to you. If they only supply the one magnet, there's no point :)
Anyway - that will tell you how coarse-grained you need the calculation.
I take it the wire is expected to be lying lengthwise in the pipe?
How thick is the pipe and what is it made of?
How big and heavy is the wire?
Also see:
http://www.corrosionist.com/magnetic_response_stainless_steel.htm
... I'm guessing the wire is not stainless steel, but the discussion will give you an idea of what you are asking. eg. different kinds of steel respond differently to a magnet.
I'd expect a basic classroom bar magnet to be able to move a gram or so of steel wire through a few mm of PVC plastic though. I'd just use the biggest magnet I can easily carry.
  • · Replies 32 ·
  • · Replies 32 ·
