(Basic) Please give me advice on my u-substitution technique
  • Thread starter Thread starter 939
The discussion revolves around the technique of u-substitution in integration, specifically addressing the original poster's difficulties with applying this method correctly in different scenarios. The subject area is calculus, focusing on integration techniques.
  • The original poster attempts to analyze their integration technique, noting discrepancies in their results. Some participants question the correctness of the original poster's setup and suggest checking the integration of negative powers. Others discuss the necessity and appropriateness of using u-substitution in various contexts.
The discussion is ongoing, with participants providing insights into the original poster's approach and raising questions about the integration process. There is no explicit consensus, but some guidance has been offered regarding the integration of negative powers and the potential overuse of u-substitution.
Participants are exploring the implications of using u-substitution and its effectiveness compared to other methods of finding antiderivatives. The original poster expresses uncertainty about their technique and seeks improvement, indicating a learning-focused environment.
939
I learned integration, but I think somewhere my technique is flawed, because I consistently get certain questions right and certain questions wrong. I don't know why I started doing it this way, but I always find DX by dividing it by DU and substitute it back into the equation. Where can I improve and what am I doing wrong?
Here are two equations. First one I get right, second one wrong.
1) integral of (1 - 2x)^4 2dx
2) integral of ((5)(3t - 6)^2
U = 1 - 2x
DU = -2 dx
DX = DU/-2
(U)^4 (2)(DU/-2)
U^4 (-1)
-1 integral of (1/5) U^5 + C
= -1/5 (1-2x)^5 + c
RIGHT
2)
U = 3t - 6
DU = 3 dx
dx = (du/3)
5(u)^-2 du/3
1/3 5(u)^-1
(1/3) (-5/1) (3t - 6)^-1
WRONG
... too many brackets. From your later statements I'm guessing you want:
$$\int 5(3t-6)^{-2} dt$$
However: Your substitution seems fine - I think you need to check how to integrate negative powers.
Is the exponent 2 or -2?
Wait:
... looks here like the power has been integrated properly (if it is -2). There is a minus sign missing in the previous line.
I think that u-substitution is a technique that is used at times when it really isn't necessary. IMO, u-substitution is a good way to program a computer to do an integration, but it is usually not a good way to integrate (well, really we do u-substitution to find an anti-derivative, which we use to do integration.) So, how would I do this problem?
Let's try to find the anti-derivative of[itex]2(1-2x)^4[/itex]. Now, we have something raised to the power of 4, and so a good guess at an anti-derivative would be to just write down:
[itex](1/5)(1-2x)^5[/itex]. Now, we want to see if this is correct (ie is the derivative of our first guess what we started out with.) Well, the derivative is [itex]-2(1-2x)^4[/itex]. This is VERY close to what we started out with, in fact, it is a multiplicative constant away (what constant?) So, just divide our initial guess by this multiplicative constant and check it again, and we see that this is the correct anti-derivative.
Now, if you try to do it like this, after a while, it will become second nature. It might have seen confusing the way I described it, but I think if you write it out, it will make sense. The fact of the matter is that u-substitution can sometimes make things MUCH simpler, but, IMO, these cases are few and far between. So, use u-sub when you HAVE to, but it should be a last resort (and after practice, you will realize which integrals really "need" u-sub.)
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 22 ·
